Sponsored by: Real Truck
99 f250 transfercase
Old Mar 17, 2007 | 09:53 AM
chopperkell's Avatar
chopperkell
Question 99 f250 transfercase
i have 99 f250 w/ 7.3 PSD 4x4. it will not switch into 4x4 low or high. it has a on the dash switch.i pulled the switch out to check for power and there is none, but all fusses are good. so checked the plug on the transfer case and when i touched one of the prongs on the plug with my test light it made it switch into gear.so i had my daughter get in the truck and flip the switch in to 2wd then i hit the plug with the test light it then switched into 2wd.did the same agian for 4wd low and high and it engages every time by grounding out with the test light but it wont switch other wise. COULD ANY BODY HELP. dont know what to check next.
Old Mar 17, 2007 | 10:04 PM
Beerstalker's Avatar
Beerstalker
Sounds to me like the ground wire for the transfer case shift motor has gone bad.
Old Mar 19, 2007 | 12:53 PM
chopperkell
a ground was what i was thinking, but do u have a idea of where to start. where is the gruond on the plug what should i do. thanks
caddy
6.4L Power Stroke Diesel
Apr 5, 2014 01:23 PM
408w
24
Jan 18, 2012 08:12 AM
daleyboy
Sep 16, 2010 06:49 PM
BWPowersmoker02
Jan 2, 2010 02:33 PM
