Offroad & 4x4
6" lift question?
Old Mar 17, 2007 | 08:53 AM
Stroker4Life's Avatar
Stroker4Life
Question 6" lift question?
My buddy wants to lift his 76 f150 4x4 long box reg. cab with a 6" suspension lift. Will he have to lengthen his drive shafts? We'll probably go with the rough country lift off of ebay....$350 with shipping. It doesn't come with a pitman arm and it has rear blocks, but it will work for a beat around truck. Let me know what you guys think. Thanks
Old Mar 17, 2007 | 10:31 AM
MBBFord's Avatar
MBBFord
What size tires is he wanting to run?
IF it's anything under 36 or so, then a 4" lift would do. And since it's a beat around truck, then you could cut the fenders alittle if there was any rubbing.
The 4" lift requires a few less parts, and it's cheaper. Ok, a 6" lift might require that you lengthen the driveshaft, and it might not. I've heard many people that didn't, or only the front, but I had to do both.
A 4" lift would require: coils, 7 degree C bushings, drop track bar, extended brake lines, drop pitman arm, and for the rear, I wouldn't advice using blocks for the rear. You could either do a shackle flip, or put some add a leafs, and you could get the lift you need with either one for the rear.
For a 6" lift would would need to do that, plus, get a adjustable trac bar, radius arm drop brackets or extended radius arms, do the shackle flip and add a leafs together, might have to lengthen driveshafts, ect...
Old Mar 17, 2007 | 10:47 AM
Stroker4Life
He is going to run 35's. (forgot to mention that). As you said MBB I think the 4" would be better all around just for the fact that it doesn't require as many parts or drive shaft mods. And I am gonna try to get him away from the rear block idea. "yuck"
Old Mar 17, 2007 | 10:58 AM
MBBFord's Avatar
MBBFord
The 4" lift works perfect with 35s, and it is a couple hundred dollars cheaper than the 6".
The shackle flip in the rear would only require a few grade 8 bolts and would get you 3" of lift for the rear, which would work perfectally for a 4" lift, b/c a stock truck already sites higher in the rear. Also the few bolts you'd need to do this would be cheaper than buying blocks and u bolts.
Also, I'd try and get a different lift other than roughcountry.
You might want to get him to look at www.broncograveyard.com for the parts I listed instead of buying the roughcountry lift, then haveing to go back and buy more parts, and pay for blocks that he doesn't need to use.
Old Mar 17, 2007 | 11:00 AM
Stroker4Life
Thanks MBB I'll go and check out the web site.
Old Mar 17, 2007 | 12:20 PM
nytreeman's Avatar
nytreeman
I def agree with MBB Ford,I have a 4" Rough Country lift in my 79 Bronco on 35"s with stock shafts but it was a crappy kit with blocks and I spent as much again to buy all the rest I needed,drop pitman arm,7 degree c bushings,and drop bracket for the trac bar,and then I still had to put drop blocks on the rear of the radius arms.Pay the money and buy a good 4" kit
Old Mar 17, 2007 | 12:27 PM
nytreeman's Avatar
nytreeman
I also meant to add,you should def try Jeffs Bronco Graveyard,I'm running 6 old Ford trucks between 1969 and 79 I've bought many types of parts there over the past few yrs and its a good place to deal with.Ive never had a complaint and if you have a question call and they will help you out
Old Mar 19, 2007 | 04:06 PM
bchunter's Avatar
bchunter
I did not have to extend either driveshaft in my truck, but then again it is newer and a short box.
jdavis70
Jun 6, 2015 03:26 PM
trevorrules
Dec 15, 2013 09:04 PM
fasttrucker01
Pennsylvania Chapter
Jul 25, 2007 07:09 PM
bigun72
27
Apr 3, 2007 04:04 PM
MemorexKid
Offroad & 4x4
Feb 21, 2005 09:33 PM
