engine light on
Old Mar 17, 2007 | 08:50 AM
taz1y's Avatar
taz1y
engine light on
my check engine light come's on by i got no code's can someone help me out
thanks
Old Mar 17, 2007 | 09:06 AM
marragtop's Avatar
marragtop
First thing to do is make sure it's not overheating. If it seems to be running OK, you can disconnect the battery for 5 minutes to reset the light. If it comes back on, you need to get the codes pulled. Most Autozones will pull them for free. Call ahead to confirm. Once you get the codes, post them on this forum.
Old Mar 17, 2007 | 09:15 AM
taz1y's Avatar
taz1y
nothing is overheating and it run's fine i took the battery cable off and it worked for awhile then it came back on can i pull the codes here at home ??
Old Mar 17, 2007 | 09:55 AM
mrshorty's Avatar
mrshorty
What year Explorer? '91 to '95 are EEC-IV/OBD-1, and you can pull codes at home using nothing more than a paper clip. Put "Ford EEC-IV self test" into your favorite search engine.
'96+ are EEC-V/OBD-2. These require a scanner/code reader to get codes. You can still pull the codes at home, if you have access to such a scanner/code reader. You can buy an OBD-2 code reader for $50-$100. Some parts stores will pull codes for free in hopes of selling something.
Old Mar 17, 2007 | 05:05 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
Yes we need some more information here... what year? what engine? auto or manual? etc.
If it's a '96 or newer, keep in mind the "generic" OBDII scanners (such as those autozone use) won't necessarily pull all the codes.
Old Mar 17, 2007 | 07:30 PM
taz1y's Avatar
taz1y
91 4 liter auto 4x4 explorer it has 256800 on it and it run's great but this light is a pain in the *** so u can do it with a a paper clip thats good,and i have a OBDII scannners and thats all i need
Old Mar 18, 2007 | 07:10 AM
marragtop's Avatar
marragtop
I don't think the OBDII scanner will help you. You need an OBDI/EECIV scanner or do it with the paper clip.
Paule253
Feb 7, 2017 09:37 PM
Blarouche
Jan 3, 2017 05:15 PM
Jerry Chaney
Nov 15, 2016 07:54 AM
Scott Scheele
1997 - 2003 F150
Jan 11, 2016 09:32 PM
Noahwilliams
Aug 25, 2015 04:02 PM
