coolant smell...
Old Mar 16, 2007 | 05:01 PM
NaviShock's Avatar
NaviShock
coolant smell...
Did a search and not sure if I got the answer I was looking for. This just started happening. There is a strong coolant smell inside the cab...strong enough to make me fell nauseas. There are no visible leaks anywhere that I can see. Heat seems to be working fine. My first guess and a fearful one at that is the heater core going bad. I don't know of any other reason for a coolant smell in the cab. Thanks for any help.
Old Mar 17, 2007 | 12:05 PM
tommyleea's Avatar
tommyleea
A heater core is usually indicated by a fogged up windshield, and a wet floor. You might check under the hood. There is a fitting in the intake manifold with a hose on it that routes water to the throttle body base. It could be that hose, or the fitting itself may have rusted thru. It will produce a very strong odor in the cab. Cheers..
Tommy
Robby Nash
Apr 30, 2015 10:39 AM
zmock8
Feb 22, 2014 02:47 PM
98SurplusExpy
Jan 22, 2014 04:47 PM
nuebee
Sep 10, 2009 01:17 AM
doc898
Apr 29, 2009 08:49 PM
