99 y pipe for intercooler
Old Mar 15, 2007 | 08:28 PM
ForemanES's Avatar
ForemanES
(click here)
Hope this helps someone complete their list. I need one but cant do it for a little while.
Old Mar 15, 2007 | 10:38 PM
shanett306's Avatar
shanett306
I need one of these I just got my 6.0 cooler, but how do we know for sure its a early 99? Can you tell by the part #?
Old Mar 15, 2007 | 11:33 PM
ForemanES's Avatar
ForemanES
Ya I looked it up and its an early 99, plus it doesnt have the intake heater and has the smaller 2" intakes.
Old Mar 16, 2007 | 06:48 AM
tjbeggs's Avatar
tjbeggs
it looks to be an early 99. we are looking at the wrong side to know about the heater but the lower legs are smaller than the upper inlet/outlets so they should be the one for the 2 inch intakes. I would ask the seller for a pic of the other side but I am 99% sure its a early 99
Old Mar 16, 2007 | 09:16 AM
Dick7.3's Avatar
Dick7.3
looks like i got the high bid
Old Mar 16, 2007 | 10:09 AM
Cuda_jim's Avatar
Cuda_jim
I've been looking for one of these forever. I've seen them sell for ~$200, but Tim, tjbeggs, got a real good deal on one IIRC.
All I want one for is to make a pattern. I'm going to make my own. But I'm not joing to join the tubes together where the hot and cold pipes are touching on the OEM part. Too much heat transfer IMO.
Old Mar 16, 2007 | 07:40 PM
tjbeggs's Avatar
tjbeggs
http:///showphoto.php?photo=25370&pa...t=1&thecat=500
there is a great link to a photo (not mine) of a modifed stock y-pipe. tha flange was cut off and welded to an elbow with an expanded section to the IC then the remaining y had an elbow to recieve the incoming IC tube.
Old Mar 16, 2007 | 09:17 PM
barebackjake's Avatar
barebackjake
ill have one here soon, once the custom intakes are done for my truck...
Old Mar 17, 2007 | 05:18 AM
Cuda_jim's Avatar
Cuda_jim
Originally Posted by tjbeggs
http:///showphoto.php?photo=25370&papass=&sort=1&thecat=50 0
Tim, that's pretty much what I intend on doing except for the welded connection. I think the cold and hot pipes shouldn't touch. Banks makes something similar. I read some where (likely banks) that the hot side will tranfer as much as 100F into the cold side. IDK, but it kinda makes sense. It's amazing how much the air heats up when you compress it.
Old Mar 17, 2007 | 05:19 AM
Cuda_jim's Avatar
Cuda_jim
I'd like to see those when there are done. Just to see if my thinkin' is right.
