factory gas caps
Old Mar 14, 2007 | 08:22 PM
voltson's Avatar
voltson
factory gas caps
I'm finding it unusually difficult to find factory gas caps for my '73 F350. The style is the non-locking painted cap with the thick ridge running fully across the diameter. I believe they were used from '73 to '75, with the '76's moving to the gas door (or maybe '77's did?). For the part number experts, did Ford use this same gas cap design on other car models of the same era, or is the cap unique to the pickup only?
Old Mar 14, 2007 | 08:25 PM
Mil1ion's Avatar
Mil1ion
http://www.rockauto.com/catalog/x,ca...,parttype,5900
Checkout Cap FC-98
Need to know:
w/evap ?
or
w/o evap ?
aft tank ?
Primered Non Vented Knurled edge w/evap used on in cab, aft and midship tanks
FC-759-A
FC-760-A ....same as above but NON-Evap
FC-98 - for: SCS... Handle on top of cap w/o Evap
Old Mar 14, 2007 | 08:30 PM
Dustin1690's Avatar
Dustin1690
And yes for further info 77 was when they switched to gas doors!
Old Mar 15, 2007 | 07:25 AM
voltson's Avatar
voltson
There's no issue finding the chrome w/black handle replacements, but I'm looking for the painted oem type for the factory stock look. I can't tell on the Rockauto chart if that's what they have.
Old Mar 15, 2007 | 11:36 AM
bigperm2's Avatar
bigperm2
Voltson, Let me know if you find one, because I need one too!
Mil1ion, I am a bit confused, when I go to your rockauto link, I don't see the "FC" on the part numbers, for the most part they are all 5 digit numbers.
Thanks, for the help!
Old Mar 15, 2007 | 11:44 AM
fp_5's Avatar
fp_5
I had no luck finding a "paintable" cap for my '76. I ended up purchasing the correct replacement from NAPA, but like you said , it was chrome. I then removed the black handle and sandblasted the chrome to get rid of the shine and ruff up the surface. Then I primed and painted it. The paint seems to sticking ok since I did this more than a year ago. I left the plastic handle black because it was textured and may have looked odd painted to match, put it's still an option.
Not a perfect solution but it looks so much better than the chrome!
I was looking at Dennis's link and STANT Part # 10731 looks close and it doesn't look like chrome. Need to measure to be sure.
Frank
Old Mar 15, 2007 | 12:33 PM
Mil1ion's Avatar
Mil1ion
Those FC numbers are Motorcraft service numbers.
Check on the motorcraft site.
http://www.motorcraft.com/default.jsp
or
the Old parts guy that comes on FTE
Bill Knows him.
Old Mar 31, 2007 | 10:10 AM
voltson's Avatar
voltson
Do the factory 73-76 painted caps interchange with any other Fords of that era? I've seen Pinto gas caps that look similar, but may not be the right size.
Old Apr 1, 2007 | 10:43 AM
voltson's Avatar
voltson
Is there an on-line parts interchange resource?
Old Apr 1, 2007 | 02:07 PM
Mil1ion's Avatar
Mil1ion
No but I could post a copy of that page of the catalog.
Usually the key to all this is the Engineering Numbering/Part numbers.
If you have a part on the truck that has a NON-truck part # or Engineering number # chances are it relates to other vehicles.
ie:Cruise control part
Online parts interchange site?
I gave you the best online source I know of.
You just have to do some page turning
76ClydeF100
16
Feb 12, 2014 09:48 AM
Jay1
Apr 10, 2013 12:16 PM
bigperm2
Mar 24, 2008 02:07 PM
69crewcab
Jan 19, 2007 10:25 AM
glenn Allen
20
Sep 4, 2004 05:53 PM
