302 efi performance
Old Mar 15, 2007 | 06:26 PM
preppypyro's Avatar
preppypyro
See right now I get around 20 mpg with my 302. It is a 2 wheel drive and a 5 speed. I thought about swapping a 351w in, but stock they only have what, 10-15 more horsepower? I guess with those mods you mentioned it would add about 20 extra hp, compared to a 302 with the same mods? My dilemna is the added price, and I know for sure a 351, in my application wouldnt get better mileage, just since my truck, is like a car lol.
Thoughts, opinions?
Old Mar 15, 2007 | 08:38 PM
Blurry94's Avatar
Blurry94
An adjustable fuel pressure regulator is actually quite effective for a speed density application and open loop/WOT conditions with a mild build and no aftermarket tuning. The ECU doesn't make fuel trim changes in open loop and the 02 sensors are shut down under this condition. The tables (for speed density) are fixed so there wont be any change in the fuel with the added airflow. In closed loop the ECU does make short term fuel trim changes but the affect the FPR has is minimal (if any).
Old Mar 15, 2007 | 09:46 PM
Conanski's Avatar
Conanski
Thoughts, opinions?
Yes.. stock vs stock there is not much difference between the 2 motors in a truck. The pre roller trucks were really smothered badly. But with a cam and exhaust they really wake up, the 351 in particular is transformed. It's got so much more grunt than the 5.0 it's hard to believe. Peak HP numbers on 2 motors with similar mods would be very close... mainly because the heads only flow so much so the 351 is more restricted at upper rpms. But from idle to 3000rpm, the difference between these 2 motors is night and day. Don't just look at the HP numbers, the torque curve is where the difference lies with these 2 motors, and it's not a small difference.
That said I agree I don't think you would be able to squeeze 20mpg out of a 351. Add to that the fact you will be replacing the rear tires on a regular monthly basis. In a 2wd reg cab pickup with a worked over 351 you will be smorldering up the meats ALL THE TIME, especially when you are not trying to.
Old Mar 15, 2007 | 10:42 PM
preppypyro's Avatar
preppypyro
Replacing the tires is fine by me, its kind of the point for me doing the truck up haha. Conanski, what kind of mileage do you get with your 351?
Old Mar 16, 2007 | 08:21 AM
Conanski's Avatar
Conanski
I get 12mpg city on average, I use "the force" regularly if you know what I mean. Highway milage is pretty consistant at 17mpg though cruising 70mph.
Old Mar 16, 2007 | 10:25 AM
preppypyro's Avatar
preppypyro
Thats not too bad for highway mileage at all. I wouldnt have guessed a hopped up 251 to get even close to 17.
Old Oct 16, 2011 | 02:59 PM
89lilfoot's Avatar
89lilfoot
Sorry to butt in but, I also have a 89 f150 w/302. I recently bought a short block from an engine shop. He advertised it was a 1991 remanufactured 302. After futher investigation it turned out to be a 1979 302 out of a fairlane. I already put it in the truck and put on all accessories. It fires up and idles for about 2-3 mins. then dies and won't restart. It sounds like a major vacuum leak. My question is will my fuel injection intake bolt on to those heads match up with those ports correctly? Any advise at all would be greatly appreciated.
Old Oct 16, 2011 | 03:50 PM
Conanski's Avatar
Conanski
Yes the EFI intake will bolt right on, nothing has ever changed on the 302 with respect to the head and intake configuration so parts from all years will simply bolt on.
Old Feb 5, 2014 | 03:30 PM
Simkem's Avatar
Simkem
well i have 1992 f-150 5.0 EFi, i have super come hooker hedders, k&N full intake, 2 flowmaster 40, hp chip, msd coil, mallery hot box, and 56 mm bbk on it and all that was worth it, so do gt 40 heads and edelbrock intake 3841, and i aslo put a powertrax auto locker in it, that works the best. then you will have built 302 and it will run and look oem
mjr46
37
Aug 22, 2021 05:51 PM
Inthegarage
Mar 11, 2016 06:11 PM
steve33444
19
Dec 12, 2014 08:33 PM
redrush40
Jul 11, 2006 08:38 PM
daytoncobra
Feb 20, 2001 02:27 PM
