Fixing previous rigging.
Old Feb 3, 2014 | 12:10 PM
BakerLandscape's Avatar
BakerLandscape
As my screen name suggests, I am a mechanic for a landscaping company. We just bought a competing company out and we're working our way through their stuff. Our current project is a 1996 F-350 5.8L automatic RWD. Got the thing running quite well (should have seen it when we got it... ). Only issue we're having now is we'd like to hook up the heater (was disconnected for whatever reason by previous company). Can someone post up a picture of the hoses needed? Basically anything that wasn't vital to making the truck not overheat was removed so we are trying to piece it back together with no real clue what is missing. Seems like every time we fix one thing it turns out there are four other pieces missing. Thanks in advance.
Old Feb 3, 2014 | 02:49 PM
85e150's Avatar
85e150
A disconnected heater many times means a leaking heater core.
Do you have the heater core connections hanging out of the firewall?
You should have corresponding connections on the water pump.
I'd test that core with a hose first....
Congrats on fixing the mess btw. Good luck with it.
Old Feb 5, 2014 | 05:39 AM
BakerLandscape
Tested core with both water and air. Could not find any leaks with either.
Old Feb 7, 2014 | 08:12 PM
BakerLandscape
Ended up figuring out through a ton of google searches what was missing. Ended up making the line. It's not pretty, but at least it's hooked up now...
Low70Ford
Dec 23, 2006 11:11 AM
lowdive
1983 - 2012 Ranger & B-Series
Sep 22, 2004 05:29 PM
84bronc
1978 - 1996 Big Bronco
Nov 17, 2003 06:21 AM
jwdenney2
Feb 26, 2003 08:51 PM
cmoore
Dec 14, 2002 08:42 AM
