body lift
Old Mar 14, 2007 | 12:20 PM
malcolmm's Avatar
malcolmm
body lift
Is there any way to do a body lift on the trucks that have the steering box behind the wheels? I have not found any thing that will help. Thanks
Old Mar 14, 2007 | 12:32 PM
MBBFord's Avatar
MBBFord
Why would you want to put a body lift anyway.
What year, model is your truck, and what are you wanting to do with it?
Old Mar 14, 2007 | 12:57 PM
malcolmm's Avatar
malcolmm
Its a 1976 f150 2wd. I just want to get a better stance on it. I don't off road the truck , its an ext cab, lwb, its just to long and 2wd. I could put in spring spacers on it but that would through the wheels off center. So I thought that a body lift would be good. I would like to make it a 4x4 but have never done that before so have no clue where to start.
Old Mar 14, 2007 | 03:12 PM
MBBFord's Avatar
MBBFord
You'd be better off buying a 4x4. The conversion is pretty complicated, and could cost as much as a 4x4 truck.
They don't make body lifts for 2wds, and a body lift is the worst way to lift a truck anyway.
The springs on your truck are 31 years old, so new springs would lift the front. You could always get/make drop brackets for the I beams and that would get you some lift.
New wheels and tires do alot on there own.
Old Mar 14, 2007 | 03:13 PM
KFX400's Avatar
KFX400
I had a 76 Supercab that we did a 4x4 conversion on. It takes a couple of weeks to do if you have a donor truck.The reason the body lift won't work is it moves your steering column up and on those trucks the column mounts directly to the steering box with a rag joint. The only real way to put a body lift on is to change your steering box and steering setup.
Old Mar 15, 2007 | 07:58 PM
malcolmm's Avatar
malcolmm
What size tires will fit my truck? I want it to look good. But dont know what will fit. Right now I have 235/75/15s on the truck. They look so small.
Old Mar 15, 2007 | 08:03 PM
KFX400's Avatar
KFX400
31/10.50/15 should fit pretty well and they won't cost you an arm and a leg either.
Old Mar 16, 2007 | 01:17 AM
FordTrucksKickGM's Avatar
FordTrucksKickGM
I wouldnt do much more than a one inch body lift. It would bind the rag joint too much so I dont think its worth it.
jamestw1977
Feb 18, 2010 03:10 PM
dirtjumper01
Offroad & 4x4
Jul 20, 2007 08:29 AM
dandy210
Dec 13, 2006 08:51 AM
brooks35
Apr 21, 2004 10:05 AM
fordracing
Jul 20, 2000 11:38 AM
