351m
Old Mar 14, 2007 | 09:57 AM
blockheadbob's Avatar
blockheadbob
351m
I would like to know if the 351M can be converted to points or if there is a points distributer that will interchange?
Thanks,
Bob
Old Mar 14, 2007 | 03:18 PM
Torque1st's Avatar
Torque1st
Posting Legend
Yes, but that is the WRONG thing to do. Early 70's 351C and 400 points distributors will work. The DS-II system is the best ignition system, is simple to use, and will outperform the points systems, -not to mention maintenance and fuel economy issues.
Old Mar 21, 2007 | 03:54 PM
madax7869's Avatar
madax7869
how would you go abbout wiring the ds-II system up without a wiring harnnes
Old Mar 21, 2007 | 05:02 PM
firstonraceday's Avatar
firstonraceday
Painless wiring makes a Duraspark II harness. Go to their web site and search for part no. 30812.
Old Mar 22, 2007 | 01:26 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Thanks,
Bob
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.c...stributors.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
79 FORD
May 31, 2006 08:06 PM
79 FORD
May 30, 2006 07:23 PM
bob-63-292
Jun 22, 2004 08:26 PM
ohio bob
Feb 19, 2001 09:34 AM
