97 f150 oil problems
Old Mar 13, 2007 | 02:16 PM
mharmsen's Avatar
mharmsen
i have a 97 f150 with a 120,000 miles on it. when the truck warms up and sitting at a stop with the brake on i start to loose oil pressure, but when i touch the gas or shift into park it goes right back up, and is soild as a rock. i changed the oil pump and relieve valve.
Old Mar 13, 2007 | 05:21 PM
Ultramagdan's Avatar
Ultramagdan
Hello and Welcome to Ford Truck Enthusiasts!
Sorry to hear about your problem. You will need to post your question in the tech forums since this one is used for introductions and announcements. Click on the Forums tab at the upper left and give them a look over. You can try this forum: https://www.ford-trucks.com/forums/forum25/ or maybe this one if you have the V8: https://www.ford-trucks.com/forums/forum48/
Try them out and I'm sure you get some answers. I also recommend stopping by the Michigan chapter to see what's up in your state. https://www.ford-trucks.com/forums/forum85/
Good luck with your truck and enjoy the site!
stroked94
New Member Introductions
Oct 26, 2007 04:05 PM
fomocojake1
Jun 5, 2007 05:08 PM
jacktownfireman
Jun 2, 2007 10:33 AM
Diamonddave
Mar 11, 2007 06:15 PM
