I'm planning for special for towing a heavy duty Bronco or better shortening my F250 '90 with a Bronco Cab.
Will the cab fit if the wheelbase is redused to 105"?
It should be equiped with the 7,3l Navistar (may be turbo charged), ZF 5-42 5 speed, 10.25 Sterling follfloat axle.
I'm not very deep into Fords yet so I'll be happy for any advice.
As far as the bolts from the cabs ar at the same place, (at least 2/3 of it) it should not be difficult to bolt the Bronco on the F250 frame??
Shortening the wheelbase will be a 2 days job.
