Heavy Duty Bronco
I'm planning for special for towing a heavy duty Bronco or better shortening my F250 '90 with a Bronco Cab.
Will the cab fit if the wheelbase is redused to 105"? It should be equiped with the 7,3l Navistar (may be turbo charged), ZF 5-42 5 speed, 10.25 Sterling follfloat axle. I'm not very deep into Fords yet so I'll be happy for any advice. TIA Marc |
Heavy Duty Bronco
Sounds like you've got a lot of extra time and money on your hands. Good luck!
:-tap |
Heavy Duty Bronco
As far as the bolts from the cabs ar at the same place, (at least 2/3 of it) it should not be difficult to bolt the Bronco on the F250 frame??
Shortening the wheelbase will be a 2 days job. So far the plan! Best MarcOo. |
Heavy Duty Bronco
