Engine Temp Gauge
Old Mar 12, 2007 | 09:09 PM
FordF350Baby's Avatar
FordF350Baby
Engine Temp Gauge
I have been noticing basically since I have had my truck, about a year, that the coolant gauge has never shown in the middle, its always the 1/4 of the way, or 3/8 the way, but never comes close to half way. I was always curious to why it wasnt reading accuarately, and I thought maybe there was an actual engine problem, but as of today, as I shut the vehicle off, the coolant/engine temperature gauge stayed where it was when started, so I am figuring maybe its getting an inaccurate reading or possibly jammed from going any further than 3/8 the way? It does eventually crawl all the way down, because when I start it in the morning, its at the Cold postion, any ideas boys?
Old Mar 12, 2007 | 09:34 PM
Franklin2's Avatar
Franklin2
Mine runs around the "o" in the word "normal". I have a 195 degree thermostat in my truck, and I can tell from watching the gauge on a cold morning, that the "o" on my guage is around 200 degrees. I watch the gauge and after starting it, it rises up near the "o" and then it will suddenly fall. Depending on how cold it is, it will do this once or up to 2 or 3 times.
What's happening is the engine is warming up and then the thermostat opens. All that cold water rushes into the engine, and the thermostat closes again. It keeps doing this till everything levels out.
I think your gauge is reading correctly. If you have a 180 degree thermostat and a large radiator, it will probably read to the left even more.
Old Mar 13, 2007 | 01:12 AM
Mil1ion's Avatar
Mil1ion
Ford Gauges and monitoring system has always been questioned for their reliability.
The gauges in 70's trucks used to PIN to the high side occasionally for no rhyme or reason.
It's just something we dealt with by cleaning the cluster real good.
Old Mar 13, 2007 | 08:54 AM
FordF350Baby
OKay, thats a relief, cuz it does functio, just doesnt make a man feel god inside. Lets put it this way, every once in a while, it will reach the "N" in the word Normal. As of tomorrow, I am having a Superduty Transmission Coller installed to help the tranny out so the radiator doesnt need to work as hard. MAybe that might make it even go to the left even more.
Old Mar 13, 2007 | 05:04 PM
Franklin2's Avatar
Franklin2
If it reads much more to the left, you may not have much heat for the heater core on a cold day. Running the engine hot keeps down wear, cooks off bad stuff in the oil, and gives better fuel mileage.
Old Mar 13, 2007 | 06:42 PM
FordF350Baby
is this something i should get looked at?
Old Mar 13, 2007 | 06:52 PM
Franklin2's Avatar
Franklin2
If you wanted to verify your factory gauge is correct, you could go buy a aftermarket gauge and stick it in temporarily.
Old Mar 14, 2007 | 01:00 AM
Mil1ion's Avatar
Mil1ion
Have the T-stat value verified to see what temp T-stat is actually installed.
Always go with spec.
Some think they need one 20*F lower to make it cool but what they are doing is wearing their engine faster due to lower operating temps.
Old Mar 14, 2007 | 08:44 PM
FordF350Baby
good point. The transmission cooler I got today is no bigger than the stock one, but its a "heavy duty" one. Are they suppose to be as big the radioator? Or are they suppose to stay that small?
Old Mar 14, 2007 | 09:32 PM
Franklin2's Avatar
Franklin2
I have never seen one that covers the whole radiator.
Old Mar 15, 2007 | 07:19 AM
FordF350Baby
o okay. I never heard one that did either, just didnt know if i was getting ripped off after $300 including installation. But I just wanted to get one in their, even for everyday riding
Old Mar 15, 2007 | 04:12 PM
Mil1ion's Avatar
Mil1ion
Transmission coolers are usually for vehicles that tow things.
They also come in various degrees of manufacture.
Old Mar 15, 2007 | 04:29 PM
FordF350Baby
Right..Yeah I do tow heavy machinery here and there, but its doesnt hurt to have it their anyway when I slamming the gas passing little ricers in theire Civivs and Neons lol.
abstractbart
Aug 16, 2016 04:17 PM
90150xlt
Oct 23, 2015 07:06 AM
Derrrrick
Oct 22, 2015 10:46 PM
Ron1999
1997 - 2003 F150
Jul 1, 2015 12:19 PM
cpfenn
Jul 5, 2003 08:37 PM
