OK folks it's time to fess up. How much did you get done on your truck this weekend?
I got my Bronco II steering column installed. Trial fitted the seats too, but I need to replace the seat runners with the original bench seat slide.
Decided it was time to crawl under the parts truck and pull the brake pedal off, didn't know it was so much trouble to get the clutch assy. off so that the brake pedal can be removed.
Loaded some more pics to my gallery, enjoy Photo album
finally had decent weather up here. put new wheels on the "yard-truck" ie current dd. towed the totalled jeep home(now mine after the wife "willed" it to me) and found her a 99 s10 blazer lt(gasp)
yeah, the po torched it in half to free the cab from the frame, so I feel yer pain.
I got nothing done on the truck this weekend. I did, however, get my new compressor installed. I added an overhead hose reel to clear more floor space also. Very nice setup and very capable compressor. It is a 220v, 16cfm, 29 gallon job that will run everything I have and HVLP spray guns also.
i had to animal proof my garbage can bin,living in the wood's has that bad side.i did get my front spring's put back in and the front straight axle put in too.
Lots of work done........just not on my truck..........picked up a free 75 raised roof E250 camper van, possible steering column donor for the 53, its rims/tires are going on my 89 F250 4x4..... did buy some dollies to put under the wheels of the 53 so I could push it to one side of the shop...that allowed me to fit in my friends Explorer with the tranny that only worked in reverse...then proceeded to spend most of today removing the dead tranny.
All in all I guess not too bad a weekend, just never got to work on what I really wanted too :-)
Looking good Jeff. Glad you had the B II now? It became a donor too!
Brian, I almost sold it last year for $500, before I decided to use it for a donor. So far I figure I have used at least that much out of it and still sold the engine for $300.
Everything in my yard is subject to be robbed of needed parts at times. The ****** parts that found their way into the truck are from my 4 wheeling days.
Not too much progress, as you know my weekend starts Monday evening until Thursday morning. I have posted some ? under look col. on my brake drum removal if anyone wants to go give me some advice. I will be hard at it tomorrow night.
i got my engine out of the truck and the transmission too. Got the diff. cover out and am letting all the gunk drip out overnight. got two more rusty impossible bolts off.
