Do you have the manual that came with the sub? I would double check in there and make sure that you are hooking up the voice coils in series correctly.
no manual with the sub. pretty much refuse to go to a shop and pay some one to do something i know i can do haha. i'll mess around with the voice coils. Any other ideas about how to wire the voice coils???
Any other ideas? You have been drawn a perfectly good diagram of EXACTLY how to wire it up. Without being there and seeing what you are doing/working with theres not much more I/we can do to help.
I think I may have found an issue. Looking at the manual for his amp it appears that this amp is not made to be bridged. They have you run a single sub off a single output. Here is a link to the manual.
It appears that amp cannot be bridged. If so you will need to hook each voice coil to each channel. You will keep your Sony subs wired like I said before and you will wire one voice coil to each channel. Just like you did the Sony subs. Voice coil one goes to channel one and voice coil two goes to channel two. Normaly you would need to use a Y splitter to make the RCA signal mono, but the manual says its a mono amp so I guess that does not apply.
The manual I linked to is for the XM-1600GSD amplifier, in post 10 he said he had an XM-16006SD I assume the 6 is a typo and should be the G since that is the closest match on the Sony site.
Alright thanks for the links. And ya that was a typo. sorry. So, are you sayin to double up both channels. As in, one sony to each channel + one voice coil to each channel. Just making sure before I wire this again.
SPL, i wired just like the diagram showed and the 15 wouldnt even turn on...
The only question i really had about that was the wire going from the one voice coil to the other... is that supposed to be just a single piece of wire???? going from one pos. to the other neg.???
EDIT: by the way, my buddy has a 550 watt 2 ch. bridgeable amp hes willing to sell to me for 40 bucks. he bought it (from meijers) for 100 new. I'm gunna hook it up to my truck and see how it sounds this week.
It may be easyer for ya just to get that 40 doller amp and put in a small power distribution bar. Then all you would have to do is piggy use the pre out on the sony amp and jump it over to the new amp then just wire it up. Also you shouldn'y have ant worreis about stressing that sony amp.
What is with you and "stressing the amp"? Once again, the amp is designed to run at two ohms stereo as pictured in the manual. I would not recommend something to him that would potentially damage his equipment without first stating that the method could do such. What I am asking him to do is not hard. I do it all the time and it would take me about 30 seconds to do if I was there. What I am asking him to do is a very common method of hooking up four subs to a singal amp.
