Help! Camper Shell Window Broken Seattle
Old Mar 10, 2007 | 07:45 PM
reddawgg's Avatar
reddawgg
Not sure what the best forum would be for this, but here goes:
Passenger side sliding window was broken out recently of my '00 Stockland canopy. Been calling RV repair shops, auto glass shops, etc., to get this window fixed...all I seem to get in response to my question is the "10,000 Yard stare." Oh, and of course, we'll be happy to sell you a new, custom canopy.
This is the Sebring model; window is the sliding portion (psnger side). Anyone know of a shop that fixes such things in the North of Seattle area?
Thanks a bunch!
'00 F250 Lariat 7.3
Old Mar 12, 2007 | 11:05 AM
jim henderson's Avatar
jim henderson
I am surprised a auto glass shop won't cut you some glass to fit. I once had custom mirrored glass cut to fit a camper for my ricer way way long ago. It wasn't that expensive.
I think the key was to minimize the amount of work they had to do. All they want to do is cut glass. What I did was remove the glass and hand it to them so they could use it as a pattern. In your case assuming the glass on either side is a mirror image of the other. I would take the good glass to them and tell them make a matching mate to it. Worst case, make a paper pattern of the glass sitting in the good side or maybe you could rough out a cardboard replica and see if it fits in the slide etc.
Key is once they know what shape to cut, it becomes almost trivial for them to make a replica.
Goood Luck,
Jim Henderson
Old Mar 12, 2007 | 01:21 PM
reddawgg's Avatar
reddawgg
Thanks a bunch Jim. You're right, we have a mirror image of the glass on the opposite side. I wondered why they just couldn't take the dimensions from that and go to work. The tracing/template ideas would work as well. Unfortunately I'm battling an illness right now; not able to get in & work on the shell.
Shops have stated that the window frame would be destroyed during removal. Others disagree. Many have said simply they will not work on camper shells.
A complicating factor may be that this window has a curve to it. They should be able to scribe the intact glass in several places and go from there.
I have more calls to make. Making a replica should be fairly routine. I'll report back on my findings.
Thanks again.
Old Mar 12, 2007 | 02:08 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Hi Reddawgg! Welcome and thanks for joining us in the Towing forum!
Have you tried an RV dealerhip's repair facility? They would probably be more inclined to work on it since they have experience with fiberglass and aluminum coaches and trailers.
Also you said it's curved... as in convex? I was thinking if it is flat but just has rounded corners you could go with tinted lexan or polycarbonate.
Old Mar 12, 2007 | 06:20 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Have you checked with the manufacturer of the canopy? They might have a dealer near you who could help. Went to their web site and it wasn't working.
jason.gotz
Mar 23, 2021 11:10 PM
Nader
18
Mar 29, 2018 07:08 PM
CountryBumkin
May 2, 2017 06:08 PM
Turbo Dog
Aftermarket Products
Feb 20, 2016 10:58 PM
rob442
1983 - 2012 Ranger & B-Series
May 9, 2001 10:43 PM
