ZF-5 Reverse Gear
Old Mar 10, 2007 | 06:25 PM
Winger235's Avatar
Winger235
ZF-5 Reverse Gear
Currently have a 1991 remanufactured ZF-5 (542) transmission out of a 1986 F-350 dump truck 6.9L has all the updates to join the two and works great. This rig belongs to a friend of mine who pulled it out because reverse kept jumping out of gear. His father took it to someone and it has been there for close to a month now. Long story short this guy says he can't find a reverse gear rebuild kit for this trans. Now since it has been pulled apart by someone else makes it a little to much taboo for me. Does anyone here have a line on where I can get this reverse gear and apparently there is an updated version that eliminates this gear jumping issue. The money this guy is talking to do the job I am almost leaning to tell him get another reman. Any Help would be great!
Old Mar 10, 2007 | 09:14 PM
Dave Sponaugle's Avatar
Dave Sponaugle
If I can catch my drive line guy tomorrow I will find out where to get the gear for you.
Did the rest of the transmission work right?
Is the guy doing the rebuild changing any other parts?
Old Mar 10, 2007 | 10:40 PM
Winger235's Avatar
Winger235
I have driven this truck and it works really well. It does jump occassionally out of reverse. The rest works and shifts spot on. This guy is a GM mechanic but supposedly has worked on these transmissions. He says it is the reverse gear and that there is an update reverse gear for this trans. I know GM is using the ZF-6 against the D-Max and maybe he is confusing the two I really don't know or know him. My buddies Dad is stubborn as they can get and he really wants this guy to fix it but a month later?
The GM guy is saying 2 things and course this is 3rd party. But he is talking 800 dollars. I have worked on these and the bearing and synchro kits are 500-600 all by themselves. So, to answer a question I really don't know what he is doing. Just says he can't find a reverse gear kit. I would greatly appreciate your help on this.
If I can help this project along and not have to get the basket case myself all the better. Local shops here seem to be either hacks or just parts changers so I have been getting some blank expressions. Thanks again!
Old Mar 14, 2007 | 05:49 PM
Winger235's Avatar
Winger235
Success! GM guy went out of his way and found a specialty transmission shop and direct ordered from them. Total kit cost 200 and change. I will find out more and which company so I can pass it along to everyone here.
Old Mar 18, 2007 | 10:32 AM
soupy264's Avatar
soupy264
The big problem with the ZF trans is the fact that Rev is a syncro.Most of us Ford drivers are used to shifting a reverse gear, so a little grinding into reverse is no big deal. That little grind,in the ZF's, eats the reverse syncro up . The replacement parts are like buying a piece of Europe,$$$$$$$$$.And since 5th and REv are the same syncro..... ouch. Phil
Old Mar 18, 2007 | 10:37 AM
Pele's Avatar
Pele
I've always been accustomed to shifting into 1st then to Reverse, while fully stopped in any vehicle I'm in to eliminate the grinding on a non-synchronized Reverse... Wouldn't this practice save the synchro?
Old Mar 18, 2007 | 10:45 AM
soupy264's Avatar
soupy264
Pele: Yes,I think that is a good practice. I found that just taking the little extra time to ensure the truck is stopped made it work well. I had learned the bad habit while snow plowing. Just had to retrain my self to slow down a little. Now I've done the next better thing, go to Florida for the winter, let other guys plow. LOL. Phil
bigbubba87
28
Sep 27, 2024 11:11 PM
BuzzRanger99
1983 - 2012 Ranger & B-Series
Dec 12, 2022 12:01 PM
Old_Yeller
Nov 11, 2009 09:17 AM
91f2504x4
21
Jan 23, 2009 12:56 PM
johnboy427
1978 - 1996 Big Bronco
Apr 4, 2006 10:15 AM
