Any Problems with Biodiesel??
Old Mar 11, 2007 | 09:37 AM
kennedyford's Avatar
kennedyford
It would be because the manufacture did not remove all the glycerine or worse complete the reaction thus it is just veggie oil build up. Like dumping grease down your pipes in cold water. Home made bio has much higher personal standards then commericial. When I can run it I run 100 percent. When I finish making my own I will always run 100. Correctly made bio will go right in at 100 percent without any problems and add power and quiet diesel knock. I had to pull over the first time to make sure my truck was running right because I couldnt hear the engine.
Old Mar 11, 2007 | 09:39 AM
Lovin7.3's Avatar
Lovin7.3
How often would I have to change the fuel filter? Or how would I know it needs to be changed? besides the truck quit running
Old Mar 11, 2007 | 10:05 AM
its back's Avatar
its back
Could someone direct me to a report from an independent source on bio? The only ones I have found are from companies that are bias one way or another for their own good. It's cool that he care about my family so much to do whatever he can to save us $$$, but I want to save $$$ on fuel cost and have his support.
Old Mar 11, 2007 | 10:12 AM
Fire Rooster's Avatar
Fire Rooster
Originally Posted by its back
I was talking to my service manager (close relation) tonight and he told me about a PSD not sure if 7.3 or 6.0 that came through the shop last month. They basically needed to replase the whole fuel system because of the lard build up. Would this be caused by the glycerin not being removed or not being thoroughly washed? If not What could have caused this?
This was either very poor quality BD. Or it was not even bD it was straight veg oil. BD will not leave faty deposits in the fuel system if it is made right. As for non-bias info go to biodieselcommunity.org or biodieselnow.com
I have run my own home brew in both my 7.3L for nearly three years now. I also just bought a mercedes diesel and am running BD in it too.
Old Mar 12, 2007 | 08:24 PM
richochet's Avatar
richochet
bio diesel
I have been running B11 year round, no problems, but maybe a little harder to start. However, my fuel mileage improved about 2 mi per gal with bio
Old Mar 12, 2007 | 08:35 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I was running B100 for a few tanks last year and my truck loved it. When the weather stays above 40-45* this spring i will change back over to some sort of blend of Biodiesel.
CruiserClass
Indiana Chapter
Feb 9, 2011 11:00 AM
superpony18
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Dec 21, 2006 04:13 PM
esmarkey
25
Mar 8, 2006 06:19 PM
r_maddox
Mar 29, 2005 07:35 PM
ColtM4
Feb 19, 2005 06:20 AM
