hummmm, buddys excursion starts fine, but has no throttle responce and no gauge cluster movement at all, the only code was for no throttle responce,
bigtorque, if you get me the exact code I can get you a copy of the schematic for that as well to help you pin point the problem. As for all gauges inoperative, this is from my Mitchell on Demand guide:
Let me know if that worked, you should be able to zoom in to read it.
Oh yeah one more thing, I don't know the year of your buddy's Excursion so that guide is for an 01. Ford changed wiring harnesses in 02 so if it's an 02 or newer let me know I'll get you the guide for that.
Check for blown fuses, i was replacing my shifter arm when the wires broke and they got grounded and blew the fuse for it, nothing in the cluster would work, would start up but not take throttle. I don't remember which fuse it was though i blew. The truck would just sit there and idle.
Sorry, just caught where you said all fuses checked. That was a problem i had one time though.
