I’m losing differential fluid and I need to get some now but the only place open is Autozone. I’ve lost some fluid and need to put something in there so I can get it to the shop on Thursday. Can I mix differential fluids? Would Autozone have anything that would hold me for two days?
Specifications:
<O</O
2001 F350 Super Duty 4x4 with a Dana 4.10 rear end.<O</O
I agree with John, axle seal, the seal on the inside of your drum, my truck was leaking at the axle seal when I purchased it, not as bas as yours sounds though. I replaced the seal myself, with the correct tools it's not too bad of a job.
