06 F250 Stroked 4WD Crew Shortbox No Lift (STOCK)- I have read alot of threads on this question I'm about to ask with different answers all over the board. What is the LARGEST tire I can put on this truck? Thanks Guys.....
It really depends on what rims you have on the vehicle. But generally speaking, any 35X12.5R** will fit the factory rim with no modifications to the truck or its suspension.
not sure about that. I tried some 35X12.5's on stock spec. wheels and had slight rub on inner fender. I used a 1/4" spacer to eliminate the rub and eventually lifted the truck.
I assume you mean the fender liner. Yes, that does happen sometimes but most people drill a small hole in the liner and pull it back with a zip tie and it takes care of that problem.
I would be shocked if 35 x 12.5's would fit on the front of my '02 SC diesel, without a leveling kit.
It might be possible. I had alot of people say I cound not 35"s on my truck. I was almost even convinced myself, but I was able to fit 35X12.5R18's on my stock wheels and stock suspension. They do just touch the leafs and barely rub the fender liner at full turn. Other than that they fit perfect.
'02 and '04 are very similar other than engines and front axle, so I can not tell you for sure.
35's translate into 315's? What do you guys recomend on a tire for mostly highway/street driving, boat ramps in the summer, and occasional light off road? Thanks alot!
What rims are you going to use? I am assuming factory 17"s?
