Problem in rear end
Old Mar 9, 2007 | 05:38 PM
shanes76's Avatar
shanes76
Problem in rear end
I have a problem in my rear end, you can pull both axles out about an inch, what is the part called that holds them in place?
Old Mar 9, 2007 | 05:41 PM
fflintstone's Avatar
fflintstone
c-clips. You might want to park it till you fix it. If you tow it to the shop, use a flatbed.
Old Mar 9, 2007 | 05:47 PM
shanes76's Avatar
shanes76
can I buy thesew seperate?
Old Mar 9, 2007 | 06:08 PM
Fordsflylow's Avatar
Fordsflylow
A 99 Ranger with that much play! Wow! Do you pull a trailer with it?
Anyone know what's considered normal play of the axles?
Old Mar 9, 2007 | 06:12 PM
shanes76's Avatar
shanes76
no i dont, never pulled anything
Old Mar 9, 2007 | 06:17 PM
fflintstone
not an inch. As far as i'm concerned, the only thing keeping her from coming right out is a piece of the c-clip is stlill in the groove. I would'nt drive it another 10 ft. you'll have to tear the diff apart and inspect the works as per the manual instructions. Lay out all the parts in order so that they all go back the same, especially the shims. You'll find bits and peices in there, so account for them as to the broken parts.
good luck
fred
Old Mar 9, 2007 | 06:22 PM
shanes76's Avatar
shanes76
can I buy the clips seperaye though?
Old Mar 9, 2007 | 06:30 PM
Fordsflylow
I doubt it unless you get em from a salvage yard! You should have someone put in a kit. It's an art and requires special tools working on diff's, I wouldn't recommend it as a diy project.
I just checked OReilly's online and it appears all they sell are kits. Something is not right in there for it to be worn that bad already so a kit might just be your best bet! How many miles you have on it?
Old Mar 9, 2007 | 06:31 PM
shanes76's Avatar
shanes76
133000, how much is the kit?
Old Mar 9, 2007 | 06:49 PM
Fordsflylow
Depending on the size it'll be around $75, but that's just OReilly's. Might want to check around at other parts stores.
Good luck!
Old Mar 9, 2007 | 06:52 PM
Fordsflylow
BTW That's just bearings, seals and such, not gears. It'd be best to have it torn down first by a reputable shop to see what it needs, they may be able to get specific or seperate parts rather than a kit.
Old Mar 9, 2007 | 09:00 PM
budman-mo's Avatar
budman-mo
If you have an inch of in/out then you will probably find worn side gears or worse the carrier is really worn out. Also possible the axles have worn into the spider pin?
Those C-clips are only about 3/16" thick so if worn it still wouldn't be that much.
I wouldn't drive it anywhere.
Old Mar 9, 2007 | 09:02 PM
shanes76's Avatar
shanes76
it has a slight jerk stopping and taking off also
Old Mar 10, 2007 | 04:47 AM
shanes76's Avatar
shanes76
anyone got any links as to where so info or pics of the inside of the diff.? Also Does anyone know what gears these came out with, its a 3.0 . One other thing it dont have the jerk taking off till it warms up.
