1978 - 1996 Big Bronco
Stumbles when starting engine
Old Jul 25, 2002 | 08:29 PM
1stBronco's Avatar
1stBronco
I have a '96 Bronco w/ 351 engine. Whenever it sits for about an hour, it will idle low and erratic. Should I try fuel injection cleaner as I have heard that there is a coating on some surfaces that manual cleaning may damage? Any suggestions on repair before winter in Wisconsin?
Old Jul 25, 2002 | 08:51 PM
honney's Avatar
honney
I'd ask a shop to pull the codes. Could be IAB or a dirty throttle body, or even ECT. I'm not familiar w/OBD-II, tho
Old Jul 26, 2002 | 04:06 PM
1stBronco's Avatar
1stBronco
The check engine light is not on. Would codes still exist?
Old Jul 26, 2002 | 04:15 PM
honney's Avatar
honney
Yes
Old Jul 26, 2002 | 06:46 PM
Oldfordtech's Avatar
Oldfordtech
If you can duplicate this concern try disconnecting the vac. line to the egr valve and then start the engine. If the problem goes away the egr vac. regulator is sticking. I see that all the time at work. At work I use a vac. gauge and you can see abought 3 inches of vacumn on a cold start and it will drop to 0 real quick. Just a possibility. Norm.
Old Jul 27, 2002 | 11:42 AM
1stBronco's Avatar
1stBronco
[updated:LAST EDITED ON 27-Jul-02 AT 01:08 PM (EST)]Yep, that did it. Removed and plugged vac line and engine runs fine. Do you clean or replace this thing? If I remove the vac line from the egr and leave it plugged, what harm can I cause? Will I get an engine code indicating poor egr flow?
Old Jul 28, 2002 | 07:19 PM
Oldfordtech
You need to replace the regulator. I think there about $35.00. If you leave the egr inop. you will get a check engine lite, prone to ping, and the passages and valve will plug up. Not worth it. The egr does nothing bad when working right.
Old Jul 29, 2002 | 04:48 PM
1stBronco's Avatar
1stBronco
Thanks, I will replace it. BTW, once the engine gets running, there is no problem, except for lower gas mileage.
Old Jul 31, 2002 | 12:52 AM
ZiVvmO's Avatar
ZiVvmO
could that be my problem also.....stutters and jerks after sitting for a few hours, also tends to not want to start after sitting overnight.......takes 2 or 3 times for it to stay running
Old Aug 1, 2002 | 08:52 PM
1stBronco's Avatar
1stBronco
Replaced the EVR and now the engine purrs when starting. No stumble or poor idle. Dealer only part though, $31.95:+
Old Aug 1, 2002 | 10:30 PM
jmackie's Avatar
jmackie
Saleenguy
Wisconsin Chapter
216
May 31, 2009 10:33 PM
fastfarmer
Wisconsin Chapter
442
Mar 31, 2009 09:21 PM
topfisherman
Wisconsin Chapter
27
Mar 12, 2005 11:16 PM
fordcowgirl
30
Dec 17, 2002 11:37 PM
