Code 1280 - ICP/PCM ???
Old Mar 8, 2007 | 07:31 PM
trike1946's Avatar
trike1946
Question Code 1280 - ICP/PCM ???
I have a code 1280 on my 97 E series. I have no boost at all. The turbo looks good, and from the turbo to the engine looks good. Does not seem to leak. No vacuum leaks that I can find at all. But it runs like an IDI instead of a PSD. I replaced the IPR about 2 months ago. The tube under it looked clear. If I am not mistaken that has to do with boost. The wires all look good. In the explanation of the code it mentions the PCM. Could I have a PCM problem as well as the ICP? Does the ICP also control boost? Thanks for any help.
Old Mar 9, 2007 | 12:32 AM
fishmanndotcom's Avatar
fishmanndotcom
have you tried pullin the ICP and letting the truck run in default mode? could just be the sensor
-cutts-
Old Mar 8, 2011 | 06:05 PM
MONAVIERONJON's Avatar
MONAVIERONJON
At one time i had similiar scenario with a minimal oil drip,snugged up the oilpan and had boost.Doubt icp has anything to do with boost although could be wring.
Old Mar 8, 2011 | 06:51 PM
Action4478's Avatar
Action4478
Try unplugging the electrical connector on the Map sensor ...
Also , make sure the hose running to it does not leak ...
fordpride
15
May 23, 2016 01:00 PM
Kugo
22
Aug 22, 2015 07:47 AM
Pitcrw6
May 17, 2015 03:52 PM
The Solar Guy
Mar 25, 2015 01:45 PM
quesey
Aug 29, 2014 09:54 PM
