V-8 to I6 - Engine miss
Old Mar 7, 2007 | 09:15 PM
pnj89's Avatar
pnj89
1989 Ford Ecoline E250 had a 302 v-8 with 4 speed auto transmission
I'm replacing the V-8 with a 1988 rebuilt 4.9 L 300 ci inline 6
Problem: Cylinders 2, 4 & 6 are not firing properly.
I have the 1989 service manual covering both V-8 and I6.
I need to know the top dead center No. 1 position after
compression stroke. Are pistons 1 and 6 supposed to be
at top dead center or are pistons 1 and 5 supposed to be
at top dead center. I cannot find this in the manual.
Engine is currently set with 1 and 6 at top dead center.
FYI: I have already checkec and eliminated the following possible problems:
1) distributor firing order is correct
2) compression checks out at 150 on all cylinders so unlikely to be a lifter problem
3) I rotated the engine and checked both exhaust and intake valve closure
against distributor - the cam location checks out with the distributor rotation
4) I have traced out and check ohms on all the rewiring I did and found
no problems
5) I have no means of checking the computer or the distributor module
6) I do not think I have a means of checking the injectors and I don't
know who to trust to buy new ones from
7) I've checked vacuum to the extent I can with 3 cylinders not working
properly
I do not know if it is not firing properly or is not getting fuel properly.
Any thoughts on what I should try next?
PNJ89
Old Mar 8, 2007 | 07:38 PM
acheda's Avatar
acheda
#1 and #6 TDC occur at the same time. This is built into the shape of the crank, so it is hard to get wrong without breaking the crank.
I would suspect you may have an EFI problem which is out of my realm, but I posted to say I am impressed by your trouble-shooting process. Good luck.
riverbottom
1997 - 2003 F150
May 24, 2022 02:04 AM
John Hubacek
Apr 22, 2013 01:45 PM
Solomon_Man
Dec 6, 2010 11:01 AM
jimford6
Sep 13, 2008 06:44 PM
geoaigel
Modular V8 (4.6L, 5.4L)
Dec 29, 2005 10:46 PM
