Need more computer help
I'm convinced there is data on the disk but it just seems like the FAT is messed up and I just can't see it. The drive seems to be functioning physically as far as I can tell - the Western Dig diagnostic says it is working.
Anyone have ANY ideas of what I can try? The kid has some photos of a deceased friend she would like to get back. (Please, no lectures on backing up stuff - I know better and she has heard it all from me).
Thanks as always.
Ray
There are some demos you can try for free but the recovery ability is limited to a specific, read small, file size. Try "Recover My Files" free demo just to give you an idea of what it will find on the disk.
It'll probably take 4 hours give or take a couple, to do a full scan of a 200GB drive... that is not a malfunction.
If that sees it as 10m Then something is wrong.
If you use disk management it will show all partition info
Usually there are small FAT32 partitions and large NTFS partitions..
As Mi1lion said look at My Computer and see how many drives you have..
Maybe you are just looking at the wrong partition...
F-1 at startup will bring the Bios up. Just arrow to the Primary HD and Secondary HD. Secondary my not be listed as a slave on load, if so the computer will not recognize it. It will be like having another cd rom. loads quick, but never identifies it as a HD.
I don't remember what the BIOS was seeing. I know it saw the drive but I can't remember the details. I'll check that this afternoon.
My Computer was seeing the drive as two drives - G: and H: with one being the recovery console and the other being the main hard drive. This is the one it was seeing as 10MB. Like all my HP machines recently, the hard drive is partitioned into the NTFS drive (C drive) with the windows recovery on a FAT partition (D drive). So, it is still seeing the two partitions. Just not correctly it appears.
Now that I have a couple questions to answer, I will gather that and repost this afternoon. Thanks for the help.
What operating system?
Are the two HDDs on the same channel / ribbon cable?
Are the jumpers set as 'slave' or 'cable select'?
(Try putting the slave on the second channel as a 'Master'.)
If the pc is still not seeing the 200 gig HDD, try putting it in another pc.
(That's easy at my house. There's 9 pcs in use. 1 MAC.)
Last questions. . . .
Is/was there an anti-virus program running?
What sort of failure did your neice experience, to begin with?
When looking at properties in My Computer it only shows it as a 10MB drive. It is showing the other partition of the drive as 6.4 GB - that is the recovery software.
The OS is XP.
The drive is a SATA drive so it uses a small cable that plugs into the motherboard directly. There is no jumper setting on a SATA drive
I tried to put the drive into one of my machines but they all use IDE or SCSI drives.
There was antivirus software running - I believe it was McAfee. The failure was that the OS wouldn't boot and the harddrive became inaccessible. Not much more to describe it - it just quit working. When I look at what files are showing on the drive, it has the recovery disk (now G
and the H: (what was C
just has a Windows folder on it with a bunch of gibberish named files.I tried running disk defrag and got this warning
"Drive H: has a 12-bit FAT partition. Disk defragmenter does not support 12-bit FAT partitions. To use Disk Defragmenter you must upgrade to a 16-bit FAT, FAT32 or NTFS file system"
Any thoughts other than taking the BFH to it?
The free demo is limited to small files but it will show you everything that's there.
Other than that, sounds like the hammer is the next option.
Oh yeah, in recover my files, do the 'complete file search" option.
I'll look into that for a future 'rescue'. (Thanks, furball.)
As for the 12 bit FAT. . . that's a new one on me, also. I'll have to look that one up. I'll walk down to the IT department and speak to one of the 'whiz kids' to get their opinion. (Believe it or not, two of them still use pocket protectors!)
I'm thinking of a possible 'killer' virus. I'm not much of a McAfee fan.
I'm a big fan of Trend Micro's "PC-cillin". They have an online virus checker that you might try running, too.
I then bought the software and have saved thousands of pictures and other files the kids want. Gigs of data saved. I am very impressed.
Thanks a bunch for the tip, Furball. I have a very grateful niece and a couple half-assed grateful nephews who just want their machine back so they can get back into the World of Warcraft.
