ID my differential?
Old Mar 7, 2007 | 08:05 PM
Indy Mike's Avatar
Indy Mike
Question ID my differential?
It's a 71 F100 w 302, 3 speed. the tag on my differential reads: Line 1: WDM AC OJB Line 2: 25 8.7 317A
Can anyone tell me what I have from this? I am guessing it's an open differential and want to shop on line for a positraction diff but would first like to know what my ring gear size is (9" ??) and what the gear ratio is. I can run at 50 to 80 mph and it makes no difference in gas milage; always right around 13 mpg.
BTW, I will be pulling the clutch soon to see if they sold me the right one for the V8; not the 6. Looks like all the support to the bell housing and transmission is solid and based on your feedback, will be trying out a new clutch. This is to solve the reverse gear shake Im having. Thanks for the input.
Mike
Old Mar 7, 2007 | 10:09 PM
Mil1ion's Avatar
Mil1ion
Posi is GM term so you don't want one of them.
Limited Slip or Traction Lock for Ford
WDM AC OJB (Plant ford engineering info)
2:25 8.7 317A 2.25:1 ratio 8.8 ring gear
317A (plant code)
Must be a car axle.
http://www.ridgenet.net/~biesiade/Fordrears.html
http://www.kevinstang.com/Ninecase.htm
http://www.badshoeproductions.com/rear.html
Old Mar 8, 2007 | 08:55 AM
Dave Severson's Avatar
Dave Severson
It would appear someone may have changed the rear end out, or at least I didn't know that the 8.8's came in a '71???? Maybe Numbers will jump in here and clarify.
By the way, not all of us are quite so word sensitive, Posi-trac to me still covers a Ford, even though it may not be "correct" with the purists. Anyway, found this in Widpedia about positraction:
Factory Names
In the 1950s and 1960s many manufacturers began to apply brand names to their LSD units. The most famous of these was Chevrolet's "Positraction". Since then, Positraction (often shortened to "positrac" or merely "posi") has become a genericized trademark for LSDs.
Other factory names for LSDs include
* Pontiac: Safe-T-Track
* Ford: Equa-Lock and Trac-Lok
* American Motors Corporation: Twin-Grip
* Mopar: Sure Grip
* Ferrari: E-Diff
* Fiat: Viscodrive
* TVR: Hydratrak
Old Mar 8, 2007 | 11:31 AM
Indy Mike's Avatar
Indy Mike
Thanks guys. I'm not too thin skinned. I'm gonna pull the tag off and see if I can read it any better in the garage, but I was pretty sure about the 8.7 (why not 8.8?) however, maybe I'm off a digit somewhere.
If I were to get an entire rearend at a junkyard with LSD, what codes should I look for? I think the WDM refers to open diff; what is it for Ltd. slip or the equa-loc/trac-loc?
Old Mar 8, 2007 | 01:17 PM
Mil1ion's Avatar
Mil1ion
Door tag codes for 9" Locking axles would be:
H2,H4,H6
The codes were explained in the links I made.
Did you not look in them ?
8.7 is an 8 3/4" ring gear.
Could that OJB actually be an "0J8"....? which would mean that axle was cast On September 8th 1970.
rogerranger2122
1983 - 2012 Ranger & B-Series
Oct 3, 2016 09:22 PM
mrm8174
Jul 31, 2016 03:58 PM
Daniel Winters
Feb 20, 2015 05:59 AM
Super Duty Diablo
Feb 16, 2014 09:11 AM
hogworkzinc
Aug 7, 2009 07:11 PM
