Replacing fuel tank question
Old Mar 7, 2007 | 06:54 PM
walt1968's Avatar
walt1968
I developed a leak in my saddle tank on my '96 crew cab. My question is this: Anyone have a link or a pic of the tool to remove the fuel line from the sending unit?? I haven't done a fuel tank since the early 80's and I remember the kind that wraps around the fuel line and you push it in to release the fingers. Is this still the one (not ready to dive in until this weekend in case of problems and it's only 0° here right now and I would like to have the tool on hand before then). Thanks
Old Mar 7, 2007 | 07:35 PM
bigbadwolfe's Avatar
bigbadwolfe
auto zone in my area carrys that fuell line tool just tell them u need the ford fuel line remover its like 10 bucks
Old Mar 8, 2007 | 06:51 AM
F350_Hauler's Avatar
F350_Hauler
They sell a little kit of colored plastic ones for $3.50 and the new-fangled metal one like scissors for $10. They work for fuel and A/C lines.
Put a couple of jackstands under the tank in case it is heavy with fuel or mud. You may be able to lower the tank down to the end of the long bolt threads and then reach up in there and undo the sender wire and the fuel lines.
Old Mar 8, 2007 | 07:51 AM
walt1968's Avatar
walt1968
Thanks for the input guys. I have run it down as far as I dare to, but the jack stands are a good precaution I will use.
1sscav
1978 - 1996 Big Bronco
May 8, 2015 09:51 AM
rolltide3006
Jul 24, 2011 12:37 PM
kcmark
Oct 12, 2010 12:24 PM
krol
Feb 24, 2008 05:01 PM
