99 oil leak problem and
first thanks this forum is great. i have a problem hopefully someone can help me. i have 99 expedition and i am leaving a small drop of oil everytime when i shut it off. the local mech says it is my headgasket and i called my local ford service and he siad it is a huge pain to fix and is very costly. he said if i check my oil on a regular bases and keep it at max i will be ok as long as the leak doesnt get any worse. i love my ford and have had them my whole life. my question is this true what he said, if i monitor it, it will be ok. it is just oil no coolant. the truck runs awesome and the only other problem i have is sometimes when i fill her up it goes to 430 miles till empty then i go the next time and it say 330 . it is running like new and i have 87,000 on her. i dont want to get rid of her and the headgasket is to costly for a single father of 3 small kids. so please somebody help me if you can. i am desperate. bill (bmadsen69@msn.com)
Search for oil head gasket leak, there are hundreds of threads on this. It had to do with a machining flaw way back when it was made. Either cough up 1000 dollars or live with it. It is annoying because it drips on the exhaust. I added a heat blanket that welders and plumbers use above the exhaust to collect the drips. To my surprise it has never become saturated or even shown signs of burning.
Dave
Dave
Ford publicly recognized this problem several years ago and then did absolutely nothing about it (I guess that happens when your company is drowning in red ink). Any way, cars and trucks have been leaking oil and other fluids since the day they were invented. That said, I'd just live with it and monitor the situation to make sure it doesn't get any worse.
Well I wouldn't say they did "absolutely nothing" about it. They replaced a lot of headgaskets under warranty...which then ALSO leaked. And if you were out of warranty they explained that you were totally hosed. So that's something...just something negative.
On the positive side: mine leaks and I just ignore it. As I recall the folks who really were screwed had coolant-oil leak problems...
Thats great you got some help with the leak. For those of us that didnt want to pay somebody 50 bucks to change our oil, they refused to do anything. They made it perfectly clear at the dealership that had I "used their maintenance services" they might be able to help me out. That is such a bunch of crap I cant believe it.
Brucifer3
Feb 8, 2016 04:37 PM
Frank C2
Feb 25, 2009 06:59 PM
javgag
Aug 10, 2004 09:36 AM
