cruise control surging
Old Mar 7, 2007 | 01:13 AM
xjvince's Avatar
xjvince
Question cruise control surging
The engine surges every few seconds with the cruise set, while on flat, smooth highway. Like its over controlling. Havent quite got a solid understanding of this system yet. Any ideas?
Old Mar 7, 2007 | 02:38 AM
fonefiddy's Avatar
fonefiddy
Check the plug on the unit under the hood,drivers side, next to the brake booster. I cleaned mine up and the surging stopped.
Old Mar 7, 2007 | 08:52 AM
Oregon-Mike's Avatar
Oregon-Mike
Check the thread titled "Power Brakes". There's a comment in there from Dave Long 667 that says replacing his vacuum pump fixed his cruise control. You may want to do a vacuum test to see if you're pulling 21". I'll be replacing my vacuum pump this week. My cruise was surging the first time I tried it on the maiden voyage back to Eugene from Portland. I turned it off and haven't tried it since but will as soon as I get the new pump in.
Mike
Old Mar 7, 2007 | 10:21 AM
PLC7.3's Avatar
PLC7.3
Does your vehicle speedometer work ok no flutuations.. your 94 has an electronic speed control..........no vacuum, but cable siezing is a known problem. If you need the manual I will send it later if you send me an email......
Old Mar 8, 2007 | 10:30 PM
xjvince's Avatar
xjvince
speedo works good
I'd like to pull the cable and lube it, does it remove from the control box easily? afraid the oil might effect the contoller
an e-mail is coming
thanks, Vince
Old Mar 28, 2007 | 08:03 PM
kidoo's Avatar
kidoo
Hi, I had a 1993 before and the dealer adjusted something in the differential, mine was doing that only with the camper in the box. I believe the pick up in on top of the differential. The speedo was fluctuating at around 60 miles per hours only woth cruise control on. this was a strange problem.
Old Mar 28, 2007 | 09:19 PM
xjvince's Avatar
xjvince
I lubed the throttle cable, cruise cable, and all the pivots on the IP. the cruise has been working great for a couple weeks now, and the throttle feels much better.
norm805
Mar 28, 2014 07:03 AM
mgraveman
Feb 26, 2013 08:53 AM
leardvr
Jan 5, 2009 05:10 PM
merlins'92f250d
Apr 12, 2006 07:25 PM
