stuck lifter,86 6.9
Old Mar 28, 2007 | 08:10 PM
murrhee's Avatar
murrhee
stuck lifter,86 6.9
hello agin, the #3 back lifter will not pull up from the top is there some one that knows if it will drop out the bottom if i take the cam out, the lifter next to it is about 2.5in. long,just not sure whats under there with the cam out ,any help would be awsome, thanks.murrhee
Old Mar 28, 2007 | 08:17 PM
PLC7.3's Avatar
PLC7.3
Have you got the intake and valley pan off.....with the lifter lockers removed.
Old Mar 28, 2007 | 08:49 PM
murrhee's Avatar
murrhee
stuck lifter
hi PLC7.3, yes i have all that loose and off, the back lifter guide half was broke off and the lifter was turned sideways and i think the roller end is mushroomed and will only pull up about a half an in. i am in the process of taking the radiator out to pull the cam to see if i can push it on through and grab it with a ext. magnet,whats ya think,will it work or am i just wasting my time,murrhee
Old Mar 28, 2007 | 09:29 PM
PLC7.3's Avatar
PLC7.3
Sorry never been that deep in mine....... I will check in the AM for info.....
I'm sure others will know here as to if that will work......
