General Diesel Discussion
downpipe
Old Mar 6, 2007 | 05:24 PM
jeremylillie's Avatar
jeremylillie
downpipe
i was woundering how big the down pipe is on my 06 6.0. I think it is 3.5 in, but iam not sure. I would like ot put a full trubo back exhaust system on but i have been told that if i go with a bigger down pipe that 3.5 in it will crack do to the tourqe of the engine and the fire wall. so i am trying to find away around this, if someone could help me that would be great.
Old Mar 6, 2007 | 07:00 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
The stock down pipe is 3.5 inches. However, the stock unit is flatened out a little. You can get an aftermarket TB exhaust that has a 3.5 downpipe but it isn't flatened like the stocker so you still get better flow (like MBRP). If you step up to a 4 inch DP, you may have clearance issues with your firewall. It varies from truck to truck. Some have no clearance issues while others do. Also, if you step up to a 4 inch DP, you'll lose some low end torque. I wouldn't bother with a 4 inch DP unless I was going to run a tuner at its higher setting. My $.02.
Old Mar 6, 2007 | 07:51 PM
6L PWR's Avatar
6L PWR
3.5" is all you need. I put on a 4", but I've done a few other mods as well.
Old Mar 6, 2007 | 08:38 PM
Powerstroke_wannabe
Hey 6L. If you have some extra cash laying around that you don't need, send some my way and I'll put it to good use!
Enjoy reading your posts. Keep 'em coming.
Jeremy2792
Mar 23, 2009 03:10 PM
78F150RangerXLT
Mar 22, 2009 01:56 PM
pdx02
Jan 23, 2008 12:51 PM
sfgiantsfan9
Nov 23, 2007 10:19 PM
Imdok
Oct 11, 2007 01:11 PM
