Ever Change a Side View Mirror?
Old Mar 6, 2007 | 03:59 PM
Shanester's Avatar
Shanester
4wd Low
I have a 2005 F150 Supercrew. Some goof in a Trailblazer hit my truck while parked in front of my house and broke the entire mirror off where it pivots on the driver's side. I have a replacement, but have no idea how to replace it. I am guessing that I need to remove the door panel which is something I've never done before. Any advice or help?
Old Mar 6, 2007 | 04:03 PM
mred33's Avatar
mred33
man, i would like to know also, i hit a post w mine friday. Got a quote for $157 for a replacement. Anywhere else cheaper?
Old Mar 6, 2007 | 05:36 PM
NASSTY's Avatar
NASSTY
Door Panel Removal
Remove the little cover plate behind the interior door handle w/ small flatblade screwdriver.
Remove 2 screws behind the coverplate.
Remove armrest/window switch panel cover.Start from the front of armrest/switch panel and lift the cover off the armrest,then unplug window and doorlock switches.
Remove screw from switch panel hole w/10mm socket.
Remove speaker grill,pry off with small flat blade screwdriver.
Remove 4 screws to the speaker,remove the speaker.
Remove the bottom 2 white plastic things the speaker screws attatch to.
Remove 2 screws at the bottom of the door panel.Lift door panel up and away from door while finagleing the interior doorhandle through the hole in the door panel.
It's easier than it sounds.
Old Mar 6, 2007 | 05:49 PM
Shanester's Avatar
Shanester
4wd Low
NASSTY, you are awesome!!! Thanks!
Old Mar 6, 2007 | 07:07 PM
seelyef150's Avatar
seelyef150
nice write-up Nassty! I had to do this about a week ago when a "touchless" carwash knocked mine off. The only problem I had was removing the 2 white plastic things that the speaker screws attach to. I am done, but if you know of a trick I think that would help out these other guys.
Old Mar 6, 2007 | 08:04 PM
NASSTY's Avatar
NASSTY
Grab it with needle nose pliars and pull straight out.It has a little sqaure nub on the end that fits in a sqaure hole in the door.
I just learned how to remove the door panels myself a couple weeks ago.I took one of my door panels off to tint my side windows.I got a wrinkle that wasn't gonna come out so pealed it off put the door panel back on and said to he11 with it.I'm gonna try again this weekend when I install my Mark LT doorhandles.That way if I mess up the tint it won't be a total loss.
Old Mar 8, 2007 | 11:25 AM
aguylookingforadvice's Avatar
http://www.ttt-mirror.com/pdf/Fittin...ordLincoln.pdf
I replaced my mirror about 4 months ago. These instructions are dead on. Just follow them in order and you'll have it replaced in no time. My wife borrowed my truck to go to IKEA and came back with a busted mirror on the drivers side. She said someone must have hit it in the parking lot
Who knows? Good luck!
fredo181
Escape & Escape Hybrid
Nov 1, 2012 09:21 AM
majkthreads
Jun 1, 2011 08:28 PM
mooncruiser
Aug 27, 2005 01:57 AM
wesmansr
Jan 26, 2004 09:52 PM
warmdye
Mar 21, 2003 12:25 PM
