Cold Weather Problem
Old Mar 11, 2007 | 02:38 PM
  #31
Mercx's Avatar
Mercx
I got the tube cleaned out and took it out for a spin. It ran OK for the first 5-6 miles then started missing and running a little rough. It wasn't nearly as bad as before but there's still something up there and I'm running out of things to try. Still no SES light or codes so I'm getting stumped
Old Mar 11, 2007 | 04:36 PM
  #32
Uzumati's Avatar
Uzumati
Have you ohmed out the injectors? Could be a UVC working loose.
Old Mar 11, 2007 | 05:27 PM
  #33
Mercx's Avatar
Mercx
I kind of suspect a fuel problem myself but can't really be sure. UVC harness...I don't even want to go there. Thats a knuckle breaking nightmare on the E-Series.
I'm going to try to pick up an AutoEnginuity interface and see if I can get some real time data before I dive into that one. Although, admittedly its getting harder to avoid it LOL
Have you got any info on computer requirements? From what I've seen it seems to work fine as long as you have a USB port on a laptop.
Old Mar 11, 2007 | 06:25 PM
  #34
Uzumati's Avatar
Uzumati
Make sure it is a usb 2.0 version.
If you can get to the IDM I can send you the pinout and you can ohm it from there.
Old Mar 12, 2007 | 10:21 AM
  #35
Mercx's Avatar
Mercx
Sounds good. Thats the one thing thats not too difficult to get to. I'll have to fix my multimeter but it looks like I'll be needing it.
Thanks for the help.
Old Apr 11, 2007 | 12:55 PM
  #36
Mercx's Avatar
Mercx
Its been a while but here's an update. After cleaning out the tube leading to the Exhaust back pressure sensor it was still missing a bit. After driving it a couple of times though it seemed to run fine. I think there was a little air in the fuel system that needed to be worked out from the fuel pump changeover.
Been running it regularly for about two weeks so far and everything seems fine.
I took this to 2 separate garages, including the dealership. (I really don't think they have a diesel mechanic who has any clue what they're doing) Between towing charges and labor it cost me $1800.00 to replace two batteries, an alternator and oil change and they still didn't fix it. In fact the dealership said they couldn't find anything wrong. They said, "if it breaks down again bring it back in and we'll take another look at it" Yeah...Right...as if. Then they'll charge me another $300.00 to pull the codes and feed me some more bullpucky.
I spent 500.00 on a used laptop, 350.00 for AutoEnginuity and the enhanced Ford package and 200.00 for two sensors (exhaust backpressure and injector control sensor) and its fixed. Thanks in LARGE part to the assistance received here.
So I'd just like to say thanks for all the help. You don't realize how much you depend on your car until its not working. It can cause a whole lot of stress.
Old Apr 11, 2007 | 02:00 PM
  #37
ryaneverk2's Avatar
ryaneverk2
Very, very true.
Glad you got up and running again, Mercx, and thanks for the update.
billg302
Jan 9, 2014 02:50 PM
emilyf350
Jan 15, 2011 04:12 PM
msgtg
Nov 5, 2008 06:29 AM
Oil-Pig
18
Feb 8, 2007 06:18 PM
cruster
1983 - 2012 Ranger & B-Series
Jan 24, 2005 01:09 PM
