OD light blinking shifting real hard
All the sudden the OD light comes on after a few miles n the truck is shifting hard. Anyone else get this problem? In the search saw speed sensor speedo issue but not this one. Anyone? Its a 97 exp 5.4 T load eddie baur has 2wd awd 4hi 4lo. VSS? TPS? dunno.
Thanks
JD
Thanks
JD
There are several dozen things that could cause this symptom.
You need to start by having the codes pulled. Many el-cheapo scan tools cannot pull the manufacturer-specific codes so you will need to find someone to properly pull the codes.
A local independent transmission shop would be your best bet. It probably won't be free, but you should get a preliminary idea of what is wrong.
Until you do this, it is a waste of time to speculate on what might be wrong.
Steve
Steve
magnethead
11-29-2007 11:37 AM
elrod2020
11-25-2006 04:07 PM
Morley
05-02-2005 08:13 AM
Navistar444
01-16-2005 10:58 PM
f150xlt96
04-05-2003 10:30 AM
