When the rear wheels break loose, the A4WD on my '97 engages with a lurch and a heavy 'RUNK' sound. It's a bit better in snow, when the wheels slip gently, but in the wet, it engages pretty hard. It's always been like this, and the system works, but I'm just wondering if they all act like that? Thanks.
Mine does the same thing. It seems to depend on how hard I'm "on it". As you said, if they slip on wet pavement, the thunk is pretty pronounce, but on snow it's not to bad. On ice I can barely feel it. I think it has to do with the amount of torque being sent through the drive train at the time it engages.
mine does the same thing it will be a real pronounced thunk. i try not to put mine into a4wd if at possible. if it is snowing i will just put it into 4h and watch my speed
05 EB, does the same thing. Was not as bad on my 98 X. It's bad enough to make you cringe when it happens because some 4x4 componants are taking hits that they shouldn't. It's like you are reving the engine in neutral and throwing it into gear which is why I have always used the 4 wheel high.
Which brings up another question. Does anyone have any 4x4 noise or vibration when in 4 wheel high at 50 mph or above? This 05 is the 1st Ford product I have owned that sounds and feels out of balance over 50. My other trucks I couldn't even tell if it was in 4wheel until I turned on the dry asphalt. They tell you to keep the speeds down in 4 wheel drive but I have never had a problem with the higher speeds way back to the late 70's models. Feels like a bad U-joint or a loose drive shaft in the front but before I get into it I'd figure I'd ask.
I keep my 03 XLT FX4 in AWD 99% of the time. Only when I come to a stop and shift into Reverse do I hear a Definite and Pronounced Thunk coming from the Rearend.
On occaision I'll shift into 2WD and usually after a long pause all of a sudden awful sound as if I had shifted gears on a non syncromesh transmission at the wrong RPM.
It's Definitely not a Good/Reassuring sound!
Lawrence
My 97 xlt isn't nearly as bad as some of you described on your rigs but it is definitely noticable. No clunks but there is a slight jolt when it engages. I have ridden in expeditions where it was much worse than mine though. I have driven an 02 explorer in the snow and it felt like the front end was going to come rolling out of it when it kicked in and there was no 4wd selection. I must say the wife's escape is very smooth shifting into 4wd compared to mine.
Ya know to tell you the truth I can't remember mine ever being that bad. A barely audible clunk if anything. Now I had an '03 F350 that sounded and felt like I ran over the front end when the 4 wheel drive engaged. Makes you cringe when it happens, huh?
I drive on icy roads all winter where I am at. I have yet to really hear a thunk when my 4wheeldrive engages. I can feel a light thud but no real noise. The only noise that I hear is the front end whine when I am in 2 wheel drive. Goes in AGAIN for that tomorrow.
Mine does it. If i put it in A4WD and step on it in the snow, a nice loud clunk is heard along with the front axle engaging. I guess it is normal? For what its worth my Subaru used to engage 100x smoother.
You'll hear a whine noise come from the front differential in 4wd at higher speeds. Definitely don't turn on dry pavement in 4wd it'll bind the heck out of the front drivetrain. In snow or ice i can feel the a4wd engage but no clunk. I've never had my a4wd engage on wet roads. But, I usually keep mine in 2wd mode on wet surfaces as I feel it will still cause some binding.
Yup, I hear it too in one of my '98 Expeditions if I really get on it, dry or wet. It doesn't feel like it's actually sending power though b/c at those speeds it shouldn't be slipping any. My buddy's dad actually sold his Ford dealership so a few of my friends and I had to move his whole lot of cars about 4 miles and I had the privilege of driving an '07 Expedition EL in A4wd and it was extremely smooth. Transfer case must be gettin old in mine though
I just bought mine. I guess the noise is not that bad, I am just worried about it doing damage. My 2000 doesnt have the 2wd option. I am thinking about running a switch to turn off the 4wd unless needed. Also, there are mismatched tires on it..different brands, same size. But I have a feeling they are still different sizes anyhow. I was thinking this could be causing it to do that. I dont have the money to spend on tires right now, and these ones have plenty of tread.
It really does depend on how much throttle you're giving it when the rear loses traction. The only time my A4WD engaged I was climbing a rocky hill under light throttle, it did make a clunking sound but I believe it is normal.
