1978 - 1996 Big Bronco
engine running cool/ real cool
Old Aug 16, 2002 | 01:16 PM
Kemicalburns's Avatar
Kemicalburns
My motor runs below the N on the temp gauge. I know these gauges suck but could this be to cool and cause the performance to not be there. Ive only owned this rig for about 2 months and have no comparison. Im thinking the thermostat is like a 165. what should it be using everything is stock on the engine.
Thanks for anyones help
later
Old Aug 16, 2002 | 01:34 PM
georgedavila's Avatar
georgedavila
180. Anything lower will promote premature of the internal engine parts.
Old Aug 16, 2002 | 01:59 PM
Pilotrick's Avatar
Pilotrick
With an 88 you probably have EFI and with an EFI motor standard thermostat is a 195 degree anything lower and the computer thinks the truck is cold and will run in a cold loop. With this you will burn more gas and have poorer performance you might look at your tail pipe and see if you have blackish soot if you do then you are running to rich like in cold mode. One way to check is to but a cheap thermometer from a parts store and put on in the top of the radiator when the truck is running and this will tell you what temp your truck is running at. Hope this helps and Good Luck,
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
Old Aug 17, 2002 | 09:44 PM
rdl1320's Avatar
rdl1320
Put a piece of card board in front of 1/2 of your radiator.See if this helps.Mine does the same thing with a chip and 160 thermostat.
Old Aug 17, 2002 | 09:47 PM
rdl1320's Avatar
rdl1320
Runningaddict
Apr 7, 2016 02:22 PM
Rockledge
1983 - 2012 Ranger & B-Series
13
Mar 12, 2016 09:52 AM
coolfeet
Sep 11, 2015 08:02 PM
LineDriver 101
Jul 5, 2015 11:44 PM
MetallicaFan39
Mar 9, 2004 09:16 AM
