Aerostar Ford Aerostar
Causes for P0117?
Old Mar 5, 2007 | 04:01 PM
agryphon's Avatar
agryphon
Causes for P0117?
Hi - I wandered over from the Ranger forums... Need a little info...
97 Windstar 3.0L, Getting a Check Engine light - scanner says P0117
Engine Coolant Temp Circuit Low Input
Is there some typical cause for this, or something I should be looking for? Bad sensor, broken wire, etc?
If anyone can point me in the right direction, I would sure appreciate!
Old Mar 5, 2007 | 04:28 PM
Bear River's Avatar
Bear River
Former ******
This should be fairly self evident, there is a problem with the sensor or its wiring. Bad sensor is the primary culprit. BTW, these Windstars are nothing like Aerostars. Windstar is closer to the Taurus, so you may have more luck in a Taurus Forum. Sorry I can't be more helpful, maybe someone here has a Windstar. But I think a code like that is fairly straightforward.
Old Mar 5, 2007 | 04:47 PM
agryphon's Avatar
agryphon
Ya know, it didn't even cross my mind that the Aerostar & Windstar were way different!
BKeathB
Oct 26, 2016 11:21 AM
charlie90262
Dec 19, 2012 11:18 AM
540milotalon
Aug 15, 2012 11:08 PM
spacejesus
Apr 25, 2011 10:13 PM
149113
1983 - 2012 Ranger & B-Series
Oct 20, 2005 08:30 PM
