thanks, but after a second look it seams a bit crowded, might have to find another way. Any have a mobil cb unit in there truck? where did you run the power and coax, i have a morror mounted wilson silverload, soon to be dual whips.
Which battery should i run the power off of, or does it matter?
thanks.
i take power for the CB off of the accessory fuse tap in the fuse box.
antenna is on the headache rack, and coax goes out through a rubber plug on the driver side below the brake master.
