C6 Overdrive
Old Mar 4, 2007 | 11:01 PM
oldjag's Avatar
oldjag
C6 Overdrive
I just bought a Gear Vendors OD on Ebay for my '77 250 Supercab's C6. I'm hopeing it's small enough in diameter that it will fit without moving the upper frame crossmember just behind the trans. Anyone have one of these on a Supercab?
Old Mar 5, 2007 | 10:51 AM
seventyseven250's Avatar
seventyseven250
I don't know, but it sounds like I have pretty much the same truck, and I'm interested to find out.
Old Mar 5, 2007 | 03:30 PM
Torque1st's Avatar
Torque1st
Posting Legend
It is easy to move the crossmember if required.
Which ebay item did you get?
Old Mar 5, 2007 | 07:38 PM
oldjag's Avatar
oldjag
I got the Gear Vendors OD/electronic controller w/C6 adapter. Says good condition w/50K miles. paid 1500, so I hope it really is in good condition... GV says it's pretty cheap to rebuild in any case. Seems like you can get new ones on ebay for around 2200, but I'm not sure if that includes the C6 adaptor. The big blocks have a lot of torque so you may as well use it to pull a tall top gear when unloaded - not screaming away burning excess fuel and wearing out your engine. With the 4:11's it should drop from ~3130 RPM @70mph to around 2470 RPM.
Old Mar 6, 2007 | 04:29 AM
Torque1st's Avatar
Torque1st
Posting Legend
Sounds OK then! You may want to change out that 4.11 with a 3.07~3.50 or so. You can also get wide ratio gears to give more low end grunt for the C6 from a later tranny or just a kit from Ford or a tranny shop. An auto tranny already gives torque multiplication thru the converter so you really don't need a real high numeric ratio rear axle. With the OD unit you can split every gear and now have a 6 speed.
New OD units usually come with a choice of adapters.
Old Mar 6, 2007 | 09:47 AM
beartracks's Avatar
beartracks
I have the C6/OD with 4:11. It works out to about 3.25 in overdrive. The unit can last forever if treated right. Or not. I went 80,000 on my first one with lots of abuse. It was still OK untill I changed to synthetic fluid (per factory advice). The clutch went away soon after so I would put in fresh tranny fluid, non synthetic. I paid around $800 for a rebuild. The only thing I had to do was shorten the drive shaft on my F-100.
You can shift on the fly but at full throttle it's problematic to get it timed with the tranny shift.
Old Mar 6, 2007 | 10:28 AM
beartracks's Avatar
beartracks
Exception! Use the same fluid the unit was using/came from the factory with.
Old Mar 6, 2007 | 12:23 PM
bigperm2's Avatar
bigperm2
I have often wondered about that GV overdrive. Does it really work well as a 6 speed? How does the unit know how to shift out of OD for the 1st w/ OD to 2nd w/out OD shift? same for the 2nd w/OD to 3rd w/out OD? Plus, with downshifting, which out of the 6 gears does it go to?
Old Mar 6, 2007 | 01:38 PM
beartracks's Avatar
beartracks
The OD is just a two speed tranny on the back of your 3 speed. The first shift can be automatic at around 20mph or 40 mph or when you push the button. Pushing the button again shifts it out if your in manual mode. Otherwise it only shifts out as your speed gets very slow.
Old Mar 6, 2007 | 02:40 PM
Dave Severson's Avatar
Dave Severson
You're going to really like the od unit. I've had one in a toter truck, and one in a Super Comp dragster behind a 2 speed 'glide with a stroked big block Ford dishing out the abuse. With the extra gear in the dragster I was able to go from 4.88 gears to 5.13's, which took dang near a tenth off my 60 foot time. With the OD comin on after drive, I also managed another 12 mph on the big end. Never had a bit of trouble with either one of them. My toter had 70 some thousand on it when I sold it and got my new one 4 years ago. the guy who got it from me has driven another 50K on it, and still no problems.
