Electric choke Questions
Also, I Thought the Choke cover where the wire plugs into, is a heater. If so would it not have a set ohms of resistance, when measured to ground. Currently, I have two covers (with the bimetelic coil spring inside), and both read 'Open' ( no continuity) from terminal to ground. Are they both bad? If known what should the Resistance be
I thought about asking this in the 289-302-351W forum, but I thought that the wiring being specific to a body style.
The wire goes to the stator connection on the alternator.
I posted an illustration on this thread.
https://www.ford-trucks.com/forums/5...-a-module.html
