Exhaust Sound problem
Old Mar 4, 2007 | 01:24 PM
Hollywood2005's Avatar
Hollywood2005
I put in a cat back system with a Magna Flow Muffler ( not sure of the model) and for the most part it sound good except around 2000 RPM where it droans in the cab which I really hate.
The exhaust place says its something to do with the fuel injection system????? Which I think is bull hooey!
so I am thinking I am going to pull the muffler out and put on some bottles that I used to have on my 351W (my old truck).
My question is does anyone have bottles on their 5.4??? if so do you still have that droaning from 1800 - 2200 RPM?
thanks for any help
Old Mar 4, 2007 | 01:48 PM
jvoigt's Avatar
jvoigt
Hey I had a Magnaflow on my 99 and I think it droned a little until the packing burned in......its takes about 500-1000 miles or so to burn in the packing. Have you got under the truck and looked to make sure everything is connected? I dont know but I thought you could only get drone from a chamber muffler like Flowmaster, when I had my magna flow it sounded good but never droned and was pretty quiet.
Old Mar 4, 2007 | 01:49 PM
ReAX's Avatar
ReAX
Year, make, model, cab will help on this.
However, Is the drone coming from the front of the cab or the rear? What else have you done to the exhaust, do you still have Cats? Where does your exhaust exit? Exit can make a big difference in drone, if it is right behind the cab that will be a lot of your problem.
My crewcab F250 with 5.4L and gibson has no drone. I do have some ticking from the y-pipe, though. One possible solution is to spray some heavy undercoating above the exhaust to slow down the resonance of the cab.
Old Mar 4, 2007 | 01:55 PM
Hollywood2005
ext cab short box and the exhaust comes out behind the tires. I believe its 3" off the cats into the muffler which is as far back on the truck as possible and comes out as dual exhaust.
Old Mar 4, 2007 | 01:58 PM
jvoigt's Avatar
jvoigt
How long have you had the exhaust on? I would sit it out a little and see if the mufflers burn in and maybe the drone will go away.
Old Mar 4, 2007 | 02:04 PM
Hollywood2005
I would guess around 5000Km. Im thinking I will have to go true dual exhaust, meaning two mufflers or bottles.
Old Mar 4, 2007 | 02:12 PM
jvoigt's Avatar
jvoigt
Sorry man I cant help.....I dont remember my Magnaflow SI/DO resonating at all and I had the exact same set up(except it was a '99) but I also had 12" long ecco chamber tube's in the rear and It was nice and mellow but no drone. By the way what does 5000km translate into in miles?
Old Mar 4, 2007 | 02:26 PM
Hollywood2005
thanks for your input! I'm not feeling very smart this morning but divide the KM's by 1.6 and you got your answer
Later
Old Mar 4, 2007 | 03:05 PM
ReAX's Avatar
ReAX
If the tip is clamped on to the pipe, try pushing out a little more.
Bjames_F250
Jul 2, 2018 12:14 PM
Enomra
Jul 8, 2012 10:06 PM
scameron
Mar 18, 2009 10:27 PM
fireman28
2004 - 2008 F150
15
Jun 12, 2008 07:56 PM
smithc185
1983 - 2012 Ranger & B-Series
Sep 10, 2007 06:17 AM
