Fault Code P1211
Old 03-04-2007, 01:38 AM
wolfe1104's Avatar
wolfe1104
wolfe1104 is offline
Fault Code P1211
I was coming home tonight when I realized that I was on a long stretch of straight rode and that there was lights in sight. I figured that I would get on her alittle bit since I have never really had an opertunity to do so.
I got up to about 85-90 when I realized that the SES light came on. I wasnt paying to much attention to all my gauges at the time (watching the road of coarse), so Im not sure what the boost or rpms were running. I just figured it was the over boost fault though because the truck was running fine. For the next 20miles the truck ran fine (took some stupid kids in focus too ). I checked when I got home though and found P1211 inject control pressure above/below desired. This was also the only code.
Is this something that I need to worry about? I cleared the code and will drive it some more tomarrow.
I should probably mention that I was running the 100hp on my evo.
Old 03-04-2007, 03:10 AM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
no need too worry..your chip was asking for more fuel then the hpop could handle..mine always gets set when i run her at WOT
Old 03-04-2007, 09:04 AM
wolfe1104's Avatar
wolfe1104
Could this be a problem since I am planning on getting a DP (I was planning on 60t, 80e, 100, 140e.)
Old 03-04-2007, 09:09 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
PowerstrokeJunkie is offline
It's an excuse to get Big Oil, if you can turn that problem into a PMS-fix. But all of us guys with hot chips have this code come up every now and then when we get on the loud pedal.
Uzumati's Avatar
Uzumati
Uzumati is offline
It wont be a "problem" but you will not see the full benefit of the higher tunes. What that code means is the ICP is seeing lower or higher (typically lower when coupled with a tuner) than expected Oil Pressure in the injection control system.
Old 03-04-2007, 10:12 AM
mastertech59's Avatar
mastertech59
mastertech59 is offline
SES light = spend money soon light.
FMT
Old 05-04-2007, 01:34 PM
pullinair's Avatar
pullinair
pullinair is offline
First off SES light stands for= Spend Emergency $ Soon
Was searching for the cuase of my 1211 code I pulled today.
For the first time ever I had to lay into the pedal yesterday getting onto the highway becuase of some drivers not knowing how to drive during rush hour. Any way, left huge plume of smoke (black of course) and merged into traffic just fine. I never did get full throttle out her becuase of how fast you have to shift. (Its a stick thing). I can only imagine having an auto with a built trans and being able to sit back and floor the freakin thing. That would be cool.
Here's the thing, I've never let the beast out of the truck like that before, so I pulled codes last night to see if anything came up. Got a P1211. Read the above statements and all looks good. Just the tuner doin what I paid for it to do.
BTW, I was only in 60 tow, I love this tune over the 80 econo because the throttle isnt as touchy in the begining but as soon as you lay into it it is as fast as the 80 econo.
Old 05-04-2007, 05:50 PM
aklim's Avatar
aklim
aklim is offline
I have gotten it when towing a trailer and going up a hill but otherwise, not really. However, that soon will be fixed.
Aggie_Ford
Texas Chapter
36
07-06-2016 11:30 AM
mjtpolice76
05-23-2014 08:27 AM
mrk28645
01-07-2013 05:34 PM
viperbluelx
16
12-05-2008 12:45 PM
mick9
01-04-2006 07:48 PM
Quick Reply: Fault Code P1211
