1978 - 1996 Big Bronco
new guy
Old Mar 3, 2007 | 11:45 PM
87LSC's Avatar
87LSC
new guy
hey just wanted to introduse myself.
I have a 90 Bronco
right now its got a 90 HO block .40 over FRP B 303 cam. stock heads p&p and valves done comp came spring kit. ect. flowmaster 3" cat back.
rebuilt trans with a b&m hd shift kit.
3" body lift and 35 inch tires
just picked ip up this winter and the motor thats in it i took out of my 87 Lincoln mark VII LSC need a motor was in a pinch so used it.
any way that motor is gonna be goling back into the mark as soon as i get the body done. so I'm thining of putting a deisel into the bronco. i seen one for sale on ebay that had the swap done. has anyone here done it? just looking for info on what is compadable between the two set ups. thanks
Old Mar 4, 2007 | 07:47 AM
lostin90s's Avatar
lostin90s
Get a whole parts truck . The 5000 small parts will kill you. Wiring is different. trans ,x-fer case is different . etc. The difference in wieght of my non diesel F250 reg and a diesel f250 was 398 lbs. Throw a plow on front and its about same weight. Use heavy F350 2x4 Dually front coil springs. Your rear 8.8 May hold up long time if you put around. But it won't like the grunt of the diesel (if wasn't for speed sensor you could put 9"rear in. They do havelkits to do that though. ). Best case is put F250 or F350 this would be a strait front axle suspention in your rig. There have been several posts about this check around. Give the diesel forum guys a post and see what they say. Keep us posted.
Old Mar 4, 2007 | 02:41 PM
87LSC's Avatar
87LSC
thanks for the info. this proably wont be happening right away. but i want to get as much info as i can be for i decide for sue that this is the way to go.
Old Mar 4, 2007 | 05:05 PM
ag30265's Avatar
ag30265
The real question is which diesel you like and are thinking of using.
Old Mar 4, 2007 | 07:45 PM
87LSC's Avatar
87LSC
hadnt really thought of wich one. was gonna get info on output and reliability befor deciding what motor to go with
Old Mar 5, 2007 | 07:34 PM
lostin90s's Avatar
lostin90s
both real reliable but turbostroke is the real animal.
Old Mar 6, 2007 | 09:26 AM
Kemicalburns's Avatar
Kemicalburns
bolt in a 5.8. its a direct swap and will give you the power and still get decent mileage. the deisal swap would consist of 1ton running gear and boxing the frame. not to mention all of the wiring work. i have not seen anyone on here do it. but do a search on google for cummins bronco swap or something to that nature. took the guy 8months and had an entire wrecking yard to his disposal.
1986F150six
30
Apr 3, 2017 12:01 AM
SuperDuty93
77
Jul 26, 2016 10:49 AM
02F150LSC
1997 - 2003 F150
Nov 11, 2015 09:13 PM
powrck32
Feb 23, 2004 08:41 AM
red_rocket
Jul 30, 2001 12:48 PM
