1978 - 1996 Big Bronco
Will this tire fit?
Old Aug 30, 2002 | 01:58 AM
masterkiller214's Avatar
masterkiller214
Will this tire fit?
Im thinking of putting some 33/12.5 15 tires on my ride. Will these tires fit on the stock wheels(rims) of a 91 Bronco? Also will they fit without a lift? Two more question, what kind of gas mileage should I expect with the larger tires and how much will it effect everyday driving and performance? Sorry so many questions. I dont want to order tires that I really cant use or cant live with. Please reply. Curious minds want to know.
91 Bronco 302 4x4
Old Aug 30, 2002 | 02:10 AM
Pioneer Ford's Avatar
Pioneer Ford
Will this tire fit?
assuming that my 89 wheels are the same as yours, 33x12.5 will fit with minor rubing on the radius arms at full turn, otherwise go for it. It's hard to say about the mileage because the largher tires will make your odometer and spedometer a little bit off (slower and less miles than actual) so it might look like you're getting worse mileage, but in fact it might be just as good or even better. It just depends. As far as performance, that also depends on what type of tires you get. Mud swampers will obviously not do too well as a daily driver, so an agressive A/T is a good bet. I have Yokohama Geolander II A/T Radial's and I love them! Great off-road tread, good price and good performance on and off road. Good luck. Take a look at my gallery for a good picture of the tire tread.
Old Aug 30, 2002 | 10:27 AM
masterkiller214
Will this tire fit?
Thank you. Im gonna go for it. :P
Old Aug 30, 2002 | 07:20 PM
Zorbungi's Avatar
Zorbungi
Will this tire fit?
I put 33x12.50's on stock 8" rims and it pulled the outside and inside edges of the tire off the road, about an inch on either side. Went to 10"rims and no problem now. Go to Superford.org and it will give you a place where you can calculate the difference in the speed. If my spedometer is reading 55 I am actually doing 62.86 with the 33x12.50's. Hope this helps.
Old Aug 30, 2002 | 10:27 PM
93Bronco72's Avatar
93Bronco72
Will this tire fit?
Are the wheels the same on a '93? I think my stock rims look nice, but I want the 33's too. Will it work? What kind of problems can I expect?
Old Aug 31, 2002 | 05:07 AM
Hwy Apostle's Avatar
Hwy Apostle
Will this tire fit?
it will fit just fine
Old Aug 31, 2002 | 12:41 PM
Mauser8mm's Avatar
Mauser8mm
Will this tire fit?
[updated:LAST EDITED ON 31-Aug-02 AT 01:45 PM (EST)]Watch out if you hit a big bump you might smash your finder. i wouldn't go with anything abouvt a 32 10.5 or maybe a 12.5 on a stock rig its just not worth missing up the body.
1979 F-150 4x4 351M C-6 NP205
2001 Ranger XL
Old Aug 31, 2002 | 04:21 PM
Hwy Apostle
Will this tire fit?
