Keyless Keypad Code
Old Apr 22, 2007 | 11:07 PM
cowboy_79_1999's Avatar
cowboy_79_1999
Thanks, Found It up under the dash... Pulled out the mini glove box in the center there and could read the numbers with a flashlight through the opening.
Old Apr 25, 2007 | 09:06 PM
HomerWinzlow's Avatar
HomerWinzlow
tbozzi, I finally got to search down the BSM for the STX standard cab today. It wasnt exactly where the manual states as you found out. It is in the corner directly behind the door hinges on the left rear of the cab. Open both doors and pull back the weatherstrip around the door opening. With a large screw driver gently pop the corner panel push pins out and you will free the panel and see the module in the center area of that corner.
Old Apr 26, 2007 | 04:18 PM
tbozzi's Avatar
tbozzi
Thank you!!!
Took about 3 minutes total to remove a portion of the weather stripping, pop the panel, peek inside, the put the panel and stripping back.
thanks again
Old Apr 26, 2007 | 04:27 PM
jetgofish's Avatar
jetgofish
I'm new to the board and came across your posting! I've desperately been trying to locate the RAP module in my truck (2004 F150 Supercrew) I'm hoping that it's also on the back wall as you've inditcated! I've searched the internet high and low, called the factory and talked to my dealer ... If in fact the box is where you've indicated on the back wall I'll be super stoked to find the code!!!!
Old Apr 26, 2007 | 05:54 PM
HomerWinzlow
Yep, on the back wall behind the rear seat back on the driver side.
Old Jun 16, 2009 | 02:04 PM
tankerjp's Avatar
tankerjp
any one know where it is for a 2004 f-350 king ranch
Old Jun 16, 2009 | 06:14 PM
HomerWinzlow
Yep, on the VSM which is mounted on the firewall behind the dash. You need to have it retrieved with a scanner.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
