transmission
Old Mar 2, 2007 | 01:55 PM
stephenr's Avatar
stephenr
transmission
I have a mazda B4000 with a automatic that is slipping slightly upon moving from a dead stop in forward or reverse.
A slight hesitation when just starting out and when it gets hot it will do it up to 3 times in a very short distance. Shifts perfectly on the highway. I just serviced the trans and it still does it.
Old Mar 2, 2007 | 07:12 PM
fflintstone's Avatar
fflintstone
Are your brakes releasing fully? check to see if they heat up when driving around town.
Old Mar 3, 2007 | 06:30 AM
03 Maz B23's Avatar
03 Maz B23
Was it working fine prior to transmission service? Had a similar occcurence after having mine serviced and it was a combination of a cut O ring on trans. filter (there are 2) and a slightly low fluid level. I dropped pan ,cleaned magnet (had a lot crud on it) replaced filter and O rings replaced fluid and it solved problem. The shop I went to did a flush and dropped pan and removed filter and reinstalled it instead of replacing it with a new one and cut the O ring in the process .The O rings are supposed to be coated with new fluid prior to installing on filter and mounted in place. The sharp edges on filter make it easy to cut them if not careful.
Old Mar 3, 2007 | 06:46 AM
stephenr's Avatar
stephenr
Yes it was doing it before I put in the new filter and o rings However I did not pre oil the o rings first. my pan was very clean no sludge build up at all.
With it in park I can rock the truck (free play) 3 to 4" without the e brake being on.
When I stop and put it in park and then let off the brake it will roll forward 3 to 4" also.
Old Mar 3, 2007 | 06:48 AM
stephenr's Avatar
stephenr
I'll check the brakes the nex time I take it out. Thank You.
Old Mar 3, 2007 | 01:04 PM
fordboy_52's Avatar
fordboy_52
what year and what tanny do you have?
Matt
Old Mar 3, 2007 | 02:41 PM
stephenr's Avatar
stephenr
1998... 5R55E
Thank You
Old Mar 3, 2007 | 02:58 PM
fordboy_52's Avatar
fordboy_52
you might have the infamous valve body gasket problem
Matt
Old Mar 3, 2007 | 03:01 PM
stephenr's Avatar
stephenr
Thanks Matt ... What exactly is that gasket problem?
Old Mar 3, 2007 | 04:24 PM
fordboy_52's Avatar
fordboy_52
it blows out
Old Mar 3, 2007 | 04:46 PM
LEVEL10's Avatar
LEVEL10
stephenr
give us a call monday morning and we will try to help you out.
did you say a 1998 with a 5r55 as i will have to be sure about the trans to properly help you out, you live in pa so if your near sussex county nj we are by the ski areas right on route 94 1 mile north of route 23.
Old Mar 3, 2007 | 04:55 PM
stephenr's Avatar
stephenr
Thank you I will call you Monday
Yes it is a 98 and a 5R55E
Old Mar 3, 2007 | 05:26 PM
LEVEL10's Avatar
LEVEL10
tell mike your from fte so he helps you properly.
