having a problem with my boost gauge.
Old Mar 5, 2007 | 10:34 AM
travis dasher's Avatar
travis dasher
Originally Posted by 99 7.3 towrig
I just did the above this weeken when installing my ATS housing. got a 1/8" compression fitting to 1/8" pipe, drilled an taped the top of the Y pipe on the cold side. not sure if its from having the gauge read right from the Y or i tightend the hell outa my boots, but I see about 3-4psi increase. use to have it T'ed into the MAP hose. I now see 15-16psi going up a 6% grade at 70mph use to be 11-13psi, all with no chip
Did you have to replace the MAP line? Or did you get a connector to connect where the line was T'd? What about shavings in the pipe? Which side of the y pipe should I tap? I have seen the pipe tapped on either side.
https://www.ford-trucks.com/forums/5...tuner-wow.html
post #8.
Old Mar 5, 2007 | 11:36 AM
99 7.3 towrig's Avatar
99 7.3 towrig
i just put a barbed hose connector in the map line where the T was, I took the Y pipe off to drill an tap it. I chose to use the side that comes from the IC going down to the heads, figgured that would show what boost the engine is injesting.
Old Mar 5, 2007 | 03:21 PM
travis dasher
Do you have any pics? I just ordered the boost fitting When that comes in I will be able to work on it. Thanks again
Old Mar 5, 2007 | 06:07 PM
zx250's Avatar
zx250
Of the next Riffraff East
The AIH plug from Pure Diesel with boost fitting will serve you will. Easy to install and you should never need the intake air heater where you live.
Old Mar 5, 2007 | 06:56 PM
travis dasher
I just ordered it today hopefully it comes in this week then I can take care of this problem. Thanks
Old Mar 5, 2007 | 07:05 PM
Uzumati's Avatar
Uzumati
Here's the IAH delete plug.
Old Mar 5, 2007 | 07:27 PM
zx250's Avatar
zx250
Alan, does your engine bay always stay that clean?, cause that sure looks good. I don't think mine was that clean the day I bought it new off the lot.
Old Mar 5, 2007 | 07:36 PM
Uzumati's Avatar
Uzumati
20 years of cleaning the fire truck every day and details every Saturday do that to ya.
But now being higher in rank I get to do it on my truck instead of the red one.
Old Mar 5, 2007 | 09:46 PM
travis dasher
Thanks Alan,
I saw that pic on another post along with the link to pure diesel for the fitting and I ordered it today. Should I remove the Y pipe to tap into it or will I be ok drilling slowly with it attached? Also does it matter which side of the Y pipe I tap into? Which side will give the most boost? And most accurate reading? Thanks
Old Mar 5, 2007 | 09:51 PM
Uzumati's Avatar
Uzumati
The plug will come already taped all you have to do is put a little Tape on the fitting. You wont have to tap anything just remove the IAH and screw in the plug.
Old Mar 6, 2007 | 10:39 AM
travis dasher
Thanks guys for all the help. I will keep you posted on how it turns out.
Old Mar 6, 2007 | 11:10 PM
travis dasher
Had some time this evening to get under the hood and look at the IAH, where does the other side of this connect to? I tried to follow the line but it was pretty tight and it was dark out. Once this is disconnected I wont get any warning lights on my dash will I?
Old Mar 6, 2007 | 11:33 PM
  #28
jtharvey's Avatar
jtharvey
The red wire off the AIH go to a relay under the hood, just on the passenger side of the engine vee; the black wire goes to a bolt on the driver's side of the vee for a ground. Just pull the wires off the relay and ground. It won't set a SES light on the dash. A soft code will be set, and it will show up if you pull the codes with a scanner, but it won't affect performance and no warning lights will show up.
Old Mar 7, 2007 | 12:37 AM
  #29
travis dasher
Thanks I am just getting all the info now so when the part comes in I can get to work and hopefully there wont be any hiccups. Thanks for all the help
Old Mar 13, 2007 | 11:55 AM
  #30
travis dasher
Got my IAH delete Boost Fitting yesterday. I will be installing it this week. My MAP line was T'd so should I get a barbed fitting to connect the line back together or just replace it. I am thinking I should replace it, I do not want any more leaks. I should be able to get a new MAP line from NAPA and installing it does not look too hard. Has anyone replaced their MAP line or if anyone could give some advice, tips, tricks. Thanks
