Sponsored by: Auxito
cab air filter (searched)
Old Mar 1, 2007 | 10:54 PM
marshall99f150's Avatar
marshall99f150
has anyone changed them and where do you change it? Did it help? How much can this drag down the air in my vents? I searched and didn't see any information.
Old Mar 2, 2007 | 07:57 AM
LxMan1's Avatar
LxMan1
Most F150's do not have them. If it does, they are usually located behind the glovebox area in the ductwork.
Old Mar 2, 2007 | 08:43 AM
jimm66's Avatar
jimm66
I heard the filter would be under the glove box. I took the panel down that is under there but didn't see a filter or where it would be. If you have a filter it definitely is worth replacing it. I have a filter on the taurus and change it once a year and it is usually full of crud. We get very little dust in the car. If it was an easy mod I would do it on the truck.
Old Mar 2, 2007 | 01:28 PM
LSUtigers's Avatar
LSUtigers
yeh i didn't think f150's had them. I had one on my acura and bugs and crap would get inthere, so it is worth replacing it yourself. Very Easy if you have one.
Old Mar 3, 2007 | 09:08 PM
Gumbyagain's Avatar
Gumbyagain
I read a thread on it somewhere, thought it was here. If I remember correctly the instructions were to remove the glove box & the Filter holder is behind it.
Old Mar 3, 2007 | 10:57 PM
fire105's Avatar
fire105
I remember several post on this site saying that alot of the f150s didnt come with a filter but there is a knock out behind or below the glove box that has to be taken out, then you can insert a filter.
Old Mar 5, 2007 | 10:02 PM
ajincalgary's Avatar
ajincalgary
I bought a filter (1999 F-150) and then found the truck didn't have a cabin filter. If you lay face up on the passenger floor, looking up under the glove box, you will see a long slot about 10" x 1", molded into the plastic housing for the ventilation system. That's where the filter would go.
Old Mar 6, 2007 | 07:51 AM
jimm66's Avatar
jimm66
Don't you need a kit of parts to make that work? You didn't just slip it in that makes no sense.
Old Mar 6, 2007 | 08:17 AM
ajincalgary
Yeah, had to return the filter. Don't think there is a conversion kit for non-cabin filter vehicles.
